Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I am trying to scan and i get the message "communication error - make sure computer is connected - i am using wireless and the printer works what do i have to do to make the scanner work?
    Scholar:
  • 67 Answers
To work around this problem, you must create a Windows Firewall exception for TCP port 21. To do this, follow these steps:
  1. Click Start, click Run, type firewall.cpl, and then click OK.
  2. In the Windows Firewall dialog box, click the Exceptions tab, and then click Add Port.
  3. In the Add a Port dialog box, type Scanner and Camera Wizard in the Name: text box.
  4. In the Port number: text box, type 21.
  5. Click TCP, and then click OK.
Restart the computer and now you should be able to scan.
Cheers.!!!
Posted on May 18, 2011
Epson scanner cannot communicate
My solution was that Epson Scan was set to connect via network instead of local. (All was working fine, then it quit-something changed this setting) Try this, go to start, choose all programs, choose Epson folder, choose Epson Scan, choose Epson Scan Setting. In the pop up box set the connection to local or network, whichever is appropriate. Close the window and open photoshop and all works fine. It could be that your problem is the opposite of mine- I try switching this to the other setting even if the change is wrong, then switch it back to see if that works too.
Good Luck.
Jan 05, 2013 | Epson WorkForce WF-7520 Wide Format...
Can print but not scan
Issue The error message 'An error occurred while communicating with scanning device' appears on the computer running Windows XP.This error occurs while using the HP scanning software. If the error message appears on the computer while scanning from a networked product, click here to troubleshoot scanner communication errors for the networked product (c00897542) (in English). This document does not cover the communication error message on networked products. Solution Beforeproceeding with the solutions in this document, use the product to makea copy in order to make sure that the hardware is functioning correctly. Ifthe copy function does not work, this document will not help resolvethe issue. Search the HP Web site for a document covering the errormessage that appears on the computer while copying. Ifthe copy function works, try each of the following solutions in theorder presented. After completing the steps for each solution, test theproduct. If the product still does not work, then proceed to the nextsolution.
NOTE: Someof the following solutions require that the computer be restarted.Consider printing this page or creating a bookmark to it, so that itcan be referenced after restarting the computer. Solution one: Restart the All-in-One and the computer Follow these steps to restart the product and the computer.
NOTE: Make sure that the product is connected directly to an electrical outlet and not through a surge protector or power strip.
  1. Turn the power to the computer off.
  2. Press the power button (c01453128.gif) to turn off the product.
  3. Wait 10 seconds.
  4. Restart the computer.
  5. Press the power button (c01453128.gif) to turn the product back on.
  6. When the computer restarts, try the scan again.
  • If these steps resolved the issue, you do not need to continue troubleshooting.
  • If the issue persists, continue to the next solution.
Oct 31, 2008 | HP PhotoSmart C4385 All-in-One Printer
Printer not communicating with computer
I'm in the same boat with my Lexmark Pro208! This sucks!
Oct 13, 2012 | Lexmark Prospect Pro205 Wireless...
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
I am unable to scan with epson stylus SX105. It says, "cannot communicate with the scanner. Make sure the scanner is on, correctky setup and connected with no errors in the scanner. If using an...
Did you ever get a resolution to your problem? I have exactly the same problem with same error message - and very loud clicking noises coming from the scanner. Powering it down - allowing it to "cool" for 5 minutes will get probably 1 or 2 documents through the scanner before the error message reappears. But this is only a workaround rather than a solution.
Jan 22, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Keep getting scanning error message
How do you have the HP6110 connected to your system? This problem can sometimes be caused by using to long a cable between the computer and the multifunction printer. I would use a short cable (6 foot or less) to make sure that it's not a communications problem. This ususally manifests itself with an error message while scanning although the printing function work ok.
Apr 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
331 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
