Question about HP TFT5600 RKM (Black) 15" LCD Monitor
Hi I recently moved my tft5600 rkm and configured as before. The next time I log onto the kvm it just flashes "CHECK CABLE". Also I believe there used to be a yellow power light that is not lit. I have checked the power supply and connections under the back of the keyboard and all are powered and reseated. I have changed the UPS its plugged into and now the error message stays powered up and does not flash. I have checked the patch cable and verified it the server works on another kvm. Any help greatly appreciated.
SOURCE: Going to Sleep
got the same issue
hp pavilion 1723
Posted on Feb 02, 2008
Mark_Webber
  • 472 Answers
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Posted on Apr 09, 2008
SOURCE: no power...no light at all at the power button
Hi, have the same problem. But I have found the fault with the screen. The power supply unit in the screen has broken. 3 components damaged. One is identified but the other two has burned so well that they are beyond recognition. Wondering if someone have any pictures on the electronics inside the screen? Kind of sure that it's only the PSU that has broken. So doesn't feel good to throw away the screen, because I loved the picture. Thankful for any help. Best regards,
Posted on Jan 24, 2009
  • 10 Answers
SOURCE: Moniter went black, power button flashes yellow
it sounds like a capacitor blew from the inverter board.. if u can open it it should be obvious which one the messed up..
Posted on May 04, 2009
Mr BrokRench
  • 1623 Answers
SOURCE: I've been getting no power at all. Tried using a good known power cable and a different power outlet but still won't work. How can i open the panel to check the power button?
Hello emperez25...Sorry to hear that your LCD died on you. There are two things that normally cause this... #1..The power supply has gone out.... This would be the case if the lights on the front of the unit do not come on. You can check this with a multimeter. . #2...The inverter or the back lights are burned out. LCD displays use small tube florescent lights like the ones that are in stores and they either burn out or the inverter fails and they cease to work. This is the case if the front panel light comes on but no display can be seen unless you look VERY close. They can be repaired, but with parts and labor costs compared to the price drops of new LCD's most folks opt to upgrade....In short, get a written estimate for repair costs, if you choose to go that route. For less than 200 dollars you can get a NEW 23 inch LCD with DVI, HDMI and AGP interface with a full high definition display that supports the latest Blu-ray devices for FHD/HD true digital content.
Hope the information i have provided you is helpful...
Posted on May 15, 2009
Hi am having prob on setting my WI-FI i forgot the WI-FI/WPA Key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 05, 2011 | Computers & Internet
I have a Netgearr WGR614v8 and i dont know how to log onto it in linux, i know i can do it through a browser but im new at this. think you could help a newb? :\
First, you need to make sure that you are connected to the router via an ethernet cable. Next, you need to open the router configuration page using a web browser (I assume you have FireFox). In order to find out what address you need to type into the browser's address bar, you need to open Terminal and type "ifconfig" without the quotations. This will show you your IP address information. Note down the Gateway address and type that onto your browser. It is usually 192.168.1.1 or 192.168.0.1. Next it will ask for the username and password. Default log in information should be : Username: admin Password: password
Hope this helps!
Apr 11, 2011 | Computers & Internet
I keep getting "Cable not connected". I have
That unit is Defective, you need to call it in for an RMA. the cable broke because of moving the tray in and our of the rack and some or all connecting cables broke. The unit has to be send in and the cable has to be replaced.
Feb 25, 2011 | Avocent 1U Rm 17IN LCD Single Rail with...
I recently have updated a app for Zedge.com. I went into it, and now i am constantly getting "The app HTC Sense stopped unexpectly". I force close it but nothing happens and its freezing up my...
Hi mistybates1,
Please install "Log Collector" from Market. Next time this happens, please start Log Collector immediately and send your log data to android@zedge.net. This way we may find out what's actually going on and hopefully fix it.
- Stig from Zedge
Jan 18, 2011 | HTC Cell Phones
How to fix blue screen when trying to start computer
it will depend the error message. however; you can try this.
start you computer on safe mode. (i am telling you this will depend on error message)
to start you pc in safe mode hit F8 key simultaneously. when the windows pop up. with you down arrow in you keyboard select. SAFE MODE only. (if you go trought your log in screen you will be lucky) . if so
log in as normal. click yes for safe mode question
(THE NEXT ADVICE IS ONLY IF SYSTEM RESTORE IS ON)
i recomend you if you can log in onto your pc in safe mode to do a System reestore. because the blue screen could be a bad driver or bad update that you recently did.
so to make an system restore follow this. To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as an administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore.
  3. On the Welcome to System Restore page, click to select the Restore my computer to an earlier time option, and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.2425657.png
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as an Administrator. Then click OK on the System Restore Restoration Complete
HOPE THIS HELP
Dec 17, 2010 | Samsung NC10-14GW Notebook
HPTFT5600 RKM Tracker Ball Connector colurs goto PS2 connector
Sorry to say but there is no standard on the color of the wrie used in any brand of the mouse or key board, I GOOGLE the PS2 PIN OUT and these are what I found: http://www.burtonsys.com/PS2_keyboard_and_mouse_mini-DIN-6_connector_pinouts.html
http://www.bbdsoft.com/keyboard.html
http://www.allpinouts.org/index.php/Mouse/Keyboard_(PS/2)
http://en.wikipedia.org/wiki/PS/2_connector
You need to find out about the wiring of your track ball. Brand and model? Hope this will help.
Mar 05, 2010 | HP TFT5600 RKM (Black) 15" LCD Monitor
Hooked up a iogear cgs62 wont allow me to log onto
II had one of those with no problem at all other than many KVM's dont allow you to use some of the many extra keys you get on some of the better keyboards. If thats what you mean by connect to internet then its a common drawback of cheaper end KVM's even some of the better ones dont support fancy keyboard buttons.
Aug 09, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Compaq TFT5600 very dim display
shine a torch onto the screen. if you can see the images with light then it is a backlight issue.
Feb 25, 2009 | Compaq Rackmount TFT5600 15 LCD Monitor...
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    USB mouse not recognized
    I have similar problem. 2 inland KVM's (both have PS2 inputs, one has USB outputs) do not light or recognize my usb mouse with a PS2 adapter. They do recognize a PS2 ball mouse on the KVM's however. One of the computers (Sony vaio 1.5 GHz) does recognize a usb mouse with adapter on 2 other KVM's (Old Belkin and a Trendnet) (the second computer I have not tried in those configurations). Next I will try an optical mouse with a PS2 fitting. That did work with a fifth KVM at an auto business last week.
    Feb 18, 2008 | Dell (582RR) 16-port KVM Switch
    Computers & Internet Logo
    171 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
