Question about Samsung SCH-u740 Cellular Phone
Top flip section of phone broken,
I somehow broke the outside LCD display screen, this further caused the inside LCD screen to be damaged. I need to repair phone, can this be done AND save the items saved in memory? i have thought about buying a used replacement and switching the top flip section of the phone, is this possible?
  • Anonymous Nov 27, 2008
    would this be covered un warranty
  • DORIS QUINTANA Apr 05, 2009
    I WANT TO REPLACE THE TOP FLIP OF THIS PHONE CAN IT BE DONE??????
  • 31 Answers
I believe they would like to know if the top section can be removed and replaced. The answer is yes.
To remove the top section you must remove the outer housing around the hinged area. There is a screw on the back side of the hinge housing at the top of the back near the center. Remove this screw.
Now flip open the phone the narrow way (not to use as a qwerty keyboard, but rather as a regular flip phone), and you see a covered screw - pry out the cover carefully (use a plastic thumb tack or a safety pin maybe), and then take out the screw.
Now, the housing covering the double hinge is ready to be removed. with the phone just as you had it, pull on the housing hard to the hinge side. It should move about a 1/4 inch. Now carefully flip the phone the other way and pull hard again. (not so hard that you think you will break the plastic).
Now you will see the ribbon cable that is wrapped around the hinge parts, allowing the hinge to open both ways while maintaining connectivity, as well as two screws on the hinge mechanism.
Remove these screws, and the screen section should slide out of the hinge.
That's as far as I've gotten. The ribbon cable would need to be unplugged from one end or the other in order to totally disconnect the two main parts of the phone.
Posted on May 15, 2009
    Brigadier General:
  • 7,752 Answers
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Posted on Sep 20, 2008
SOURCE:
Screen not displaying
Hi, Most flip or slide phones all have similar cases, which is one problem called, "Flex problem".
A flex is a thread like object the is located inside the phone, It's connected to the board of the phone and too the screen of the phone.
Also it controls the phone display,(makes the phone to display).
Possible cause for flex damage is usually when the flex of the phone get worn out and weak, due to too much sliding up and down of the phone.
Whenyou replace the flex inside the phone, wala!!!, your phone is back to normal..
I would advice you contact a skilled personnel in other to prevent further damage to the phone for assistance.
Thanks for using fixya.....
Jan 08, 2011 | Samsung SGH-J750 Cell Phone
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
My LG360 screen is flipped and mirroring words backwards
hi,there are there kinds of flipping screen in phone,
and the other one is corrupted software...in damage LCD the phone will detected,and thirdly, The flex of the phone.
The flex is connected to the screen and it makes the screen display,if the flex gets damaged it will make the screen display be affected.
Sep 16, 2010 | LG CF360 Cell Phone
Screen of my phone is not showing display my phone somehow get wet with water. after that it is not showing display what should i do
hi,
there are two kinds of white screen in n72 ,the first one is because of damage LCD (glass screen) ,defective display driver (small chips that makes the display works) and the other one is corrupted software...in damage lcd the phone will detected by computer because its software is still working...because your phone have an history of water damage ,maybe your display driver is damage...it needs to replace ,but before doing that ,try to replace first the lcd by a good one,if still no display we must therefore conclude that your display driver is defective..i hope it will help you ,thanks for sharing your problem with us and trustng fixya..
Jun 17, 2010 | Nokia N72 Cellular Phone
Phone works fine if you use keyboard on outside of case. When you open phone, LCD screen displays whitescreen permanently across entire LCD.
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Jan 08, 2010 | Nokia 9300 Smartphone
My sony ericsson w380i screen blanks when i open it??
maybe ur w380i flex is damaged. (i.e. the ribbon connecting ur lcd to the board) try replacing it.
Jul 30, 2009 | Sony Ericsson W380i Cellular Phone
Nokia display become white
the crystal diode behind the lcd screen has been damaged causing this "white screen".
best chances are to replace the whole lcd screen to get the display in working order again.
cheers.
Jan 23, 2009 | Nokia 3250 Cellular Phone
How to replace the flip.
Strongly suggest you go to Ebay and purchase a used on woth working screens in the end easier and cheeper. Plus you can hold yuor old phone for parts/back up.
Or sell as working wioth bronken front screen to help pay for the new phone.
This is what I did
Jan 04, 2009 | Samsung SCH-u740 Cellular Phone
BROKEN (front) LCD Display for LG Chocolate 3
Search for "chocolate 3 lcd" on Ebay. For ~$26 and a little technical work you can replace the outside & inside LCD module.
Dec 06, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Samsung SCH-u740 Cellular Phone Logo
404 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
