My NetGear DGN 1000 N 150 wireless not supporting to open hotmail.com, yahoo.com & AOL.com
5 Suggested Answers
redhaze89
  • 854 Answers
SOURCE: netgear dgn 2000 port trigering
Port Forwarding A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Opening Pre-Defined Ports for Internet Services: 1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu. 2. Please select the service type Port Forwarding. The router pre-defined services are listed there. 3. From the Service Name pull down list, select the service that needs to be hosted. 4. Enter the IP address of the computer in the Server IP Address box. 5. Click the Add or Apply button. 6. Repeat all steps to open more ports. Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below: D. Opening Ports for Games, Applications or Custom Ports: 1. Click on Add Custom Service button. 2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box. 3. If the application uses only a single port; type in the same port number in the Ending Port box. 4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box. 5. Type the IP address of the computer in the Server IP Address box. Click Apply button. 6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation. 7. Repeat all steps to add more ports for more services. E. To Edit or Delete a Service Entry: 1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page. 2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Jun 15, 2009
govinda123
  • 2260 Answers
SOURCE: Netgear DGN 2000 won't connect to internet by cable / wifi works
I think the DHCP server on the router is not working properly and that is why your wired compuetr is not getting the IP address from the router.
The best option to resolve the problem is assign a static IP address on the wired computer.
First check the IP address of the router,
For example , the IP address of the router is 192.168.1.1, then assign a static IP on the computer in the range of the router IP address for example 192.168.1.10.
For WIN XP
START ==> Control panel => network connection => local area connection - right click on local area connection and go to properties ==> select the option Internet Protocol TCP/IP and click on properties button. Now you will the option obtain IP address automatically.
Change it to use the following IP address . Here you can assign a static IP.
Click Here for more info about networking
Posted on Oct 11, 2009
router-user
  • 550 Answers
SOURCE: Hello, i have a wireless router Netgear WNR 1000
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Posted on May 01, 2010
  • 476 Answers
SOURCE: I have a netgear DGN 3300 wireless-N router.
its either router settings or your computers internal security settings
(Anti Virus or Firewall).
I would reset it and start again personally or.........
Try running your internet connection wizard again and that will replace the existing connection to the net when its finished,
If still nothing then reset the adaptor settings
I have an example of a router set up on this link below....
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
Please rate me thanks
Posted on May 07, 2010
Access my email account
If you use one of the email services below, just follow the link to reset your password, alternatively you can contact your email provider support directly:
Yahoo
https://help.yahoo.com/kb/yahoo-account/security-questions-reset-password-sln2824.html?impressions=true
Google
https://accounts.google.com/RecoverAccount
AOL
https://account.login.aol.com/_cqr/opr/opr.psp
Hotmail
https://account.live.com/resetpassword.aspx
Dec 28, 2014 | Computers & Internet
How do i recover my old account when its been hacked?
Depending on what email service you use there will be a recover password page, alternatively you can contact your email provider support directly.
If you use one of the email services below, just follow the link to reset your password:
Yahoo
Google
AOL
Hotmail
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
Dec 26, 2012 | NetGear DGN1000 Wireless Router
Netgear G54 Wireless Router says authentication failed
To RESET the Netgear, power up the Netgear then press and hold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Dec 01, 2012 | NetGear Computers & Internet
In order to set up an apple ipad I have to enter my network name. how do I find this. Router is Netgear Wireless J-N DGN 2200 on Erthernet 4 ADSL
Hi hjandav...
Your "network name" is the name you give your wireless system, enter that name and it should work ok.
Sep 27, 2012 | Computers & Internet
Ive currently got the netgear DGN 1000 & ive currently got a HP notebook but the HP wireless network assistant does not list this modem so cannot connect, can you help?
Check the following and then try the solution:
1. Do you have other wireless devices connected?
Yes, go to solution #1, if you know the SSID then try solution #2
No, go to step 2.
2. Are there any wifi connection listed in range?
No, go to step 3
3. Go to a location were you know there is a wifi connection, can you see this connection in the wireless assistant?
No, go to solution #2
#1 my thought is you are not sure of what the SSID is, so place the laptop next to the Netgear router and chose the best wifi signal to connect to in wireless assistant.
#2 There is a switch/or button on the laptop to turn on the wireless. It is normally somewere on the side of the laptop, turn it on and it should glow blue. Now try to connect to your router.
Hope this helps
Jul 21, 2011 | NetGear DGN1000 Wireless Router
I have a netgear DGN 3300 wireless-N router. I can't seem to open any web pages. Any advise? Could it be my router settings?
May 07, 2010 | NetGear RangeMax DGN3300 Router
Cant connect using AOL software through Netgear DG834NP
tell to an supplier.
I dont know, but the AOL software maybe cant support.
Peace!
Aug 26, 2009 | NetGear DG834G Wireless Router
I have a THOMSON ST585v6sl with AOL running off
Well it may be possible, only if your wireless router supports WDS. Also, note that in DG834Gv3 , v4, v5 supports WDS. If you have v2 or v1 then it wont connet wirelss with your existing network.
Please reply if your existing wireless router has WDS and the version of the NETGEAR router so that I will provide you with the required steps to make it work wireless.
Jul 13, 2009 | NetGear DG834G Router
Wireless
try this http://www.bolthole.com/solaris/x86-laptops.html there will be alot of reading but i think it will help thanks ian C emmit6378@yahoo.com
May 11, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
