Question about Kitchen Ranges
I have a dayton mod 3le83n battery charger in like new condition that quit working. I have power to the machine. How do i find my defective part.
4 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: new charger but no ac power to pc
A common problem is for the power jack connections on the system board to go bad. They break loose from the main board because the power plug gets flexed and then the power doesn't get from the adapter to the board. No power light (or intermittent flickering) and no battery charging results.
What you need to do (or have done) is to resolder the power jack onto the board. This isn't difficult, but it involves getting the main board out to reach the solder side. In some cases the board can be damaged because of the bad connections and isn't repairable. Then the board needs to be replaced. But most often the soldering fixes the trouble.
Posted on Apr 08, 2009
TampaNative
  • 778 Answers
SOURCE: my compaq laptop work with
You may want to check the DC Jack (where the Power Supply plugs into the laptop), it may have failed?
Posted on Oct 28, 2010
SOURCE: New battery doesn't seem to
Have a similar problem. It appears that WORX puts out very poor batteries. My solution is to call the Better Business Bureau and report them.
Posted on Aug 18, 2012
I just bought a used Invacare TDX SI2 powerchair. The batteries hold only about a mile's worth of power; and now the charger is not working. No lights when plugged into the wall.
If the batteries truly are new, it could be since the charger was defective it wasn't charging the batteries properly. You can buy a three stage charger designed for gel batteries for around $30 bucks on Amazon. If it is the batteries I am afraid they are quite a bit more for replacement than the charger itself. Good Luck!
Dec 04, 2016 | Cars & Trucks
Why is the green light blinking on the ryobi battery charger
please check if the RED LED light is flashing or not. If yes, this battery may defective.
If defective, try to repeat the conditions a second time by removing and reinstalling the battery pack. If the LED status repeats a second time, try charging a different battery.
If a different battery charger normally, dispose of the defective pack.
If a different battery also indicates "Defective", the charger may be defective.
Jun 08, 2014 | Ryobi Multi-Volt Battery Charger
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
My toshiba laptop l505-s5988 is charging not installing power
Can you be able to power up your laptop using charger only? (without battery installed)
If your laptop can't be charged while on, I assume you can only charge it when it's off.
There're 2 possibilities:
1>
Your charger is defective.
It's not a total failure issue, only the built-in chipset is compromised, so you cannot get the correct voltage your laptop needed.
Your laptop will refuse to accept the charger in this condition.
2>
Your battery is defective.
You can find another toshiba l505 charger to rule out this possibility.
Aug 10, 2013 | Toshiba Satellite Computers & Internet
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
I have a dayton model 2e353a timer to turn my pool off & on. It's quit keeping time & allowed pool motor to run constantly
Replace defective timer with new one.
Did you include correct product number?
Dayton is owned by WW Grainger.
Grainger site does not show that timer number.
Internet search does not show that timer.
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=dayton+timer&op=search&Ntt=dayton+timer&N=0&sst=subset
Add a comment and describe timer in detail, and include photo posted on flickr, include number of pins or contact markings, voltage of control circuit, voltage of load circuit, and type of pump (1 or 2-speed) with HP rating for possible new timer recommendation.
Aug 16, 2011 | Amperite Dayton Solid State Timer On Delay...
My Acer laptop model number 533Z battery will not charge. I called tech support and they said leave it plugged in, in the shut down mode, for six hours and this would charge it. I have had it plugged into...
Here's one last thing that you can try. Try to remove the reinsert the battery then try to charge it (if you haven't tried it yet). If it will work then it is just a connection problem. Best way to isolate issue is to use a new battery. If not, then return it to WAL-MART. Either the battery pin or the battery contacts (which is connected to the motherboard) is defective.
Hope this helps.
Jul 07, 2011 | Acer Computers & Internet
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
JVC Camcorder - used wrong power lead to charge battery
They sell external battery chargers for these for around 10 bucks at Amazon. Just pop the battery in the charger. Beware the battery itself can be worn down or dead. It also has protection circuits right inside the battery that can be blown (maybe a small fuse too). A new high capacity battery (3 times the recording time) is also at Amazon for around $25.
Mar 31, 2017 | JVC Everio GZ-MG130 Camcorder
Types of batteries.
You can use AA disposable batteries (alkaline or lithium) or rechargeable (NiMH or Nicad) batteries. Lithium batteries last much longer, but are generally quite a bit more expensive than alkaline batteries. You should never mix old and new batteries or different types of batteries. If you use Nicad batteries, it is recommended that you use a Nicad conditioning charger to extend the life of the batteries. Note: If you use rechargeable batteries, you will need a battery charger. The camera's AC power supply does not recharge batteries.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
