Question about Samsung SCX-4828FN All-In-One Laser Printer
System Error Cycle Power SCX 4824FN - Samsung SCX-4828FN All-In-One Laser Printer
caroldon
  • 17129 Answers
SOURCE: samsung scx 4824fn system initializing.
Maybe a reset can solve so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts.
Posted on Mar 30, 2011
SOURCE: LSU Motor Error Cycle Power
i have problem with samsung laser printer ml 3470 series, lsu motor error
Posted on Apr 18, 2011
  • 111 Answers
SOURCE: How do I print envelopes in the printer Samsung
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Posted on Apr 25, 2011
  • 1570 Answers
SOURCE: SCX-4828FN,Samsung ; System Error ;
Hi
Sometimes it is cause by low power supply. Just change the power supply source.
Or the fuser drum unit is damaged and needs replacement.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
SOURCE: I have a scx-4824FN
I had the same problem. Now my MFC is working again.
You need to apply a firmware update or upgrade.
Posted on Jul 01, 2011
Please can you tell me what cause paper jam 1 sometimes on samsung 4824fn
the problem whit this printer is that the fuser unit gear is warn very fast you need to replace the gear or the complete fuser unit. But the best thing to do is get a new printer. i have fixed some of this printer more the 5 times in 2 years whit the same problem
Apr 22, 2014 | Samsung SCX-4824FN A4 Mono Laser Printer
Thick black lines when scanning Samsung SCX-4824FN
The contact image scanner is faulty or the cable from the motherboard to the contact image scanner is faulty. I would bet it is the CIS as this scanner is used in many different machines (canon,lexmark,sagem) and it gives problems in all the machines. You can usually salvage a good one from an elcheapo lexmark inkjet multifunction.
Feb 11, 2013 | Samsung SCX-4824FN A4 Mono Laser Printer
How to fix error SYSTEM ERROR CYCLE POWER in samsung scx 4828fn printer??? please help me to solve the same
this problem is fuser relatated check fuser thermostat. faulty Thermostat replace it resolve problem
Sep 29, 2011 | Samsung SCX-4828FN All-In-One Laser...
Samsung 4828fn wont print message - system error - cycle power
All SCX-4828 and SCX-4826 buyers should launch a class action lawsuit against Samsung. I have TWO identical SCX-4826 printers, purchased at the same time. BOTH developed "System Error, Cycle Power" errors within a few weeks of each other! I suspect this is a programmed "error", not that something is "worn out" but rather it is in the programming of this series of printers. In other words, I believe they are "designed" to break after a certain length of time (in my case, just over 2 years of use - how convenient for them, just out of an extended warranty). I called a Samsung repair shop and was told that it was a "Fuser" problem. How could 2 printers develop an identical problem within weeks of each other? Coincidence? I think not!
Jun 30, 2011 | Samsung SCX-4828FN All-In-One Laser...
Scx-f828fn system error cycle power
disconnect the printer from elektrik so there is no powercord connectet anny more for about 5 minutes, then connect it and try.
Apr 27, 2011 | Samsung SCX-4828FN All-In-One Laser...
Samsung scx 4824fn system initializing. printer does not want to print?
Mar 30, 2011 | Office Equipment & Supplies
SAMSUNG SCX-4824 PRINTING BUT NOT COPYING
You can reset SCX 4824 through reset software and use refill toner forver.
Jun 02, 2009 | Samsung SCX-4828FN All-In-One Laser...
Samsung SCX-4828FN All-In-One Laser Printer Logo
946 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
