Hi i have a problem in lenovo 7757 . it was working good without battery on AC power but If i fix the bettery in it then after five minuts it was turn off automatically . i have changed this battery yesterday but steel this problem are shown tell me What will be problem in this.
    Problem Solver:
  • 28 Answers
Are you getting 100% charge all the times?
Posted on May 18, 2011
How ican know battary conector valtage
Right-click the taskbar, and click properties.
Click notification area and select battery power and save.
Or go to Control Panel and there should be Power Options.
On the Advanced Tab check the "Always Show icon on Taskbar"
And save
Feb 15, 2015 | Lenovo 3000 Y400 Y400 9454 Y410 7757 Y410a...
Lenovo 7757 no power and light
IS your laptop getting charge? have you tried with if your charger is providing proper voltage? try with other charger removing battery.
IF stil you face the probelm then there could be motherboard issue.
Aug 06, 2012 | Lenovo Computers & Internet
My betteries charge very fast and in les then five minuts they'r dead
Batteries are usually bad when this happens. Suggest searching internet for replacement batteries.
Jul 09, 2012 | DreamGear Power Base Dual Charger for...
My Lenovo ac/dc adapter (charger) whose model number is PA165052LC does not work. The lenovo on it will not light up and it will not charge my laptop. What caused it to stop functioning and how can I fix...
I would plug it in without the battery first and if the laptop stays powered on your adapter probably is fine and you have an issue with your motherboard or battery. If it still does not work replace the power adapter they are cheap and its technology sometimes it just breaks! hope this helps!!
Feb 24, 2011 | DSMiller DS Miller Inc Equivalent of...
My Lenovo s10 power adaptor (Input 1.7A, Output 20V 2A) was working just now together with the battery. After i didn't used the laptop for an hour and returned to switch it on, the power adaptor isn't...
hi,
You said laptop is working fine if just using the battery,that means that there is nothing wrong with the battery itself. Can yu please try to connect the laptop directly to the power outlet without using the battery just for the mean time,remove the battery and connect the AC adapter directly to the power outlet then power on the laptop,if nothing happens,that means that there is something wrong with the AC adapter itself or the power port on the laptop.
Hope this will help...
Jan 09, 2011 | Lenovo IdealPad S10 Laptop AC Power...
Unit keeps shutting down Lenovo 7757 Laptop.
Could be related to a heat issue if it just powers off for no apparent reason.
Try cleaning your fans our with some canned compressed air available at your local retailers such as Walmart, Fred Meyers, or Walgreen's.
However, if Windows displays that it is going to shut down due to low battery, you may try gauging if your battery life has significantly decreased. Less than 60 minutes is usually a good sign to replace the battery.
If Windows is just shutting down without any messages you can attempt to clean any malware off your computer by using Malware Bytes from www.malwarebytes.com. Also looking using Microsoft Security Essentials as a normal virus scanner (free).
Nov 26, 2009 | Computers & Internet
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 Notebooks : N100 Power Failure!
Hi.. I have a temporary solution to your problem. I had the same problem. Remove the battery and the ac adapter from the laptop. Just reconnect the ac adapter without the battery and switch on the lap. Presto.. Problem solved.. It doesnt power off anymore unless u remove the ac adaptor. Usefull if u hav needed files n want 2 create a backup. Still i havent found out a permanent solution to this problem. I suspect its a motherboard fault
Jan 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Power problem with dell latitude.
This is a failed power management system on the motherboard. The power management system regulates the power input, usage, allows the machine to switch from AC t battery, and controls the charging. When this fails it can cause problems ranging from battery not charging, power on battery only, power on AC or battery but not both, no power at all, and more. You will most likely have to replace the motherboard, however, there are a few places that do circuitry and component repairs on motherboards. Google motherboard repair facilities, get an estimate, and compare the price to a new board.
Jul 29, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
