Question about Lexmark X6170 All-In-One InkJet Printer
My Lexmark X6170 is smearing all images that are about a third of the way down the paper. Everything else is printing fine.
  • Official Brand Answer
  • 3,344 Answers
Try to clean the cartridge nozzles using the printer control panel.
  1. Load paper.
  2. Press Copy.
  3. Press Options until Maintenance appears on the display.
  4. Press the right arrow until Clean Cartridges appears on the display.
  5. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  6. Print your document again to verify that your print quality has improved.
Also, check your ink levels. Make sure your ink levels are substantial for printing.
Posted on May 31, 2011
I have a brand new ink cartridge in my printer. It printed the test page ok. When I try to print envelopes, it always says paper jam (there is no paper jam) the envelopes just wont feed. It's a Lexmark...
Make sure to set the correct paper setting on the printer or the Lexmark software before sending the print job. Adjust the printer's paper guide to the correct envelope dimension.
Dec 12, 2011 | Lexmark X6170 All-In-One InkJet Printer
I am printing 3 5/8 x 6 1/2 envelopes and getting ink smears on left side. Looked inside, everything seems fine. This is a recent problem - what do I do?
Are you getting same problem when you print on regular size paper or this only happens when you print on envelopes?
Feb 09, 2011 | Lexmark E232 Laser Printer
When i receive a fax everything is perfect,when i send a fax it reaches the destination where im sending it as a blank sheet of paper
If you are able to receive fax and it is printed out fine, there is nothing wrong with your printer. If the other person is receiving blank fax, you may be placing the documents to fax in opposite way, If you are placing the paper upside ( with text ), try to face it down and fax. It should work.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | Lexmark X6170 All-In-One InkJet Printer
How do I duplex print on Lexmark x6170
Good day! Try to follow these steps on how to do duplex printing using the Print Properties settings. With a document open, click File, Print. In the Print dialog, click Properties (or Preferences, or Options, or Setup) button. The Print Properties screen appears. You'll see three main menus: Quality/Copies, Paper Setup and Print Layout. In Print Layout, select Duplexing to print on both sides of the paper. Hope this helps.
Mar 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 stopped printing text will only pint images
First, print a test page from the printer's menu and see if the black lines and text look okay on that. If there is no or poor black printing, you need to replace the black cartridges or try cleaning the cartridge's nozzle with rubbing alcohol. If that looks fine you need to check the printer's settings in its properties on the system lift of printers.
Oct 01, 2009 | Lexmark X6170 All-In-One InkJet Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Paper Feed Problems
Hello sir; Try to remove all the paper out of the tray look inside of the bottom on right side , if you find something ( such as; paper clip, stapplers,paper chip etc) remove it , otherwise find a piece businese card stick reverse way from paper exit to clear up.
Jan 02, 2009 | Lexmark X6170 All-In-One InkJet Printer
Paper has black marks only on the edge
There are several issues that will cause a problem like that.
1, As X box mentioned is a problem with the drum. That is part of what is called the print cartridge or imaging unit. There is most likely a shutter or opening in the cartridge which you can shine a flash light at and see if the defect is visible. If so you will have to replace that cartridge. I would suspect that is the most likely issue.
2. There may be something in the paper path. A small piece of paper riped off in it, something else, a piece of tape, label, etc may have made it into the machine, that will make contact with the paper and smear the image.
3. Lastly, your fuser roller may be bad causing the reprint.
How to determine where the issue is, shut the machine off while it is printing and jam the paper in the image area. See if the defect is on the paper before the fuser. Eliminates the fuser ....
Feb 19, 2008 | Lexmark C522n Laser Printer
Lexmark X6170 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
