Question about Kenmore Washing Machines
I am attempting to remove the top portion of the agitator on my model 110.28924790 Kenmore washer to replace the dog agits. I successfully removed the fabric softener piece and popped off the underlying lid to expose the cam assembly. Instead of a hex nut there is a plastic insert with a square recessed area in the middle. How do I remove this?
  • Kenmore Master
  • 8,220 Answers
You get a 3/4 drive extension and rachet and unscrew that nut (righty tighty lefty loosey) and the top portion lifts right off. It is actually easier than the old style.
Posted on May 18, 2011
Agitator won't move
Thes units have litlle plastic dogs that make the agitator agitate, and when they break it will stop.
Remove the agitator and inside there are 3 to 4 plastic dogs or ears and these are more than likely bad.
Pry the agitator cap off by inserting a screwdriver into the cap's notch
2) Pull the inner cap (if present) off - many Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator (earlier models used a 7/16" hex-head steel bolt)
On older models, grasp the bottom portion of the agitator and pull the entire assembly out of the washer. (Some recent models allow just the top portion's removal to access these 'dogs')
5) Older models - place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once just the ratchet ***'y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All '4-dog' versions use the 285770 (or #80040) kit, regardless of the cam ***'y style. (Really old agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***'y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***'y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap's rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap's o-ring too - makes it easier to snap into place)dcramer531_112.jpg
Apr 18, 2011 | Kenmore 24042 Top Load Washer
Top portion agitator not working - Kenmore 110.27812692
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27812692
and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Apr 27, 2010 | Kenmore Washing Machines
The agitator (upper portion) will not spin. If I
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Mar 02, 2010 | Kenmore 22422 Top Load Washer
The top portion of the agitator is not working
Also see the following for an illustrated description of the above.
Dec 20, 2009 | Kenmore 24032\24036 Top Load Washer
Model # is LSR8233EQO Top portion of the agitator seems loose and does not agitate properly?? Does is remove? It seems to unscrew??
you have to replace the dog's in the top ov the agitator.the part# ror this part is WPL80040462.the cost is $4.62.to replace the dog's you nead to remove the fabrick sofeiner assembly from the top of the agitator.next you nead to remove the top cap.now you nead to use a 7/16 socket to remove the bolt in the agitator.now you nead to grab the agitator at the bottom and pull it up.now yopu nead to seperate the top from the bottom.place the agitator on the floor,put a foot on both side's of the bottom of the agitator and pull up.now you the top portion of the agitator.turn top portion upside down and remove the cam.you will see the rubber dog's.replace the dog's and reverise the prossess.
Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 18, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series washer making humming sound and won't agitate
Mar 04, 2009 | Kenmore Washing Machines
Model20882990 WASHER PROBLEM
Jan 01, 2009 | Kenmore 20172 Top Load Washer
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
