Question about Panasonic NN-S559BA 1100 Watts Microwave Oven
Light turns on, time ticks down but micro doesn't run
All of this is happening, is there anyway to fix or should i just get a new one??
  • johnson5 Aug 18, 2008
    Yes it is not heating. The turn table does turn and the light turns on when I hit start. There are no unusual noises and it is quieter than usual since it isn't heating. The model number is NN-S559BA
    Thanks
  • William Miller
    William Miller May 11, 2010
    Your long subject line got cut off. Are you saying it's not heating?
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises?
    Is it louder or quieter than usual?
    Do you have the model number?
  • Panasonic Master
  • 9,098 Answers
It's likely that you have a bad high voltage transformer or magnetron.
So parts alone would be $65-75 plus shipping if you do the work yourself.
If you have to take it to a shop, that price will basically double.
This is only a 700-850 watt oven.
Most new ones are about 1000-1200W and would cost a less (maybe a lot less) than this repair.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can order Panasonic parts here.
Posted on Aug 18, 2008
GE JVM1850 turns on but turn table doesn't rotate & light doesn't come on even though timer counts down. Doesn't heat & has low hum noise. Is it worth fixing or should I buy new? It is 8 yrs old.
if you like your micro fixe it, becouse even do new micros look better when it comes to work they suck they hardly last the warranty period thats if you are lucky...
Oct 19, 2013 | GE JVM1850 1000 Watts Microwave Oven
Oven turns itself on
THE DOOR HAS A SAFETY SWITCH THAT SHUTS THE UNIT OFF WHEN THE DOOR IS OPENED KEEPING YOU FROM GETTING "ZAPPED WITH RADIATION" ACTUALLY ITS JUST RADIO WAVES, ANYWAY THE JIGGLING OF THE HANDLE TO START IT IS WHATS HAPPENING THERE. IT COMING ON IS JUST A SHORT IN THE SWITCH THAT MAY BE FROM AN ALREADY SET TIME, OR ITS JUST MAKING CONTACT WHERE ITS NOT SUPPOSED TO. ANYWAY YOU NEED A NEW DOOR SWITCH.
Dec 03, 2007 | Samsung SMH7174BC Microwave Oven
Mcc1010t magic chef micro/convection
follow this steps and fix it. God bless you
If the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
Jul 13, 2013 | Microwave Ovens
I have a Gold Star Model MV-1500MG over the range model microwave oven. Everything works except it will not heat and the turn table does not turn. While it is running everything sounds normal but does...
Hello, does the control panel light up? If it doesn't then probably the fuse has shorted. Now, if the front control panel does light up. There a number of thing going on. Door closer switch is working.
The mega-tron tube is shot or something is going on the micropressor. Now, if the mega-tron is shot. Buy a new micro wave oven and allways to recycle used appliances. GB...stewbison
Aug 22, 2011 | Goldstar MV-1526 Microwave Oven
I'm experiencing the same exact problem as theresagolde experienced. PROBLEM:Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work...
You can modify a standard, typical micro switch available at many places or, you can get an exact replacement from GE parts placed or you can try www.repairclinic.com or you can try a FixYa.com advertiser.
You are correct in trying the safety interlock switches ... they cannot stand the opening and closing of the door while the machine is running. To improve the live cycle of these tiny switches is NEVER open the door while the oven is operating.
Thanks for your question @ FixYa.com
Jul 28, 2011 | GE JVM1330BW/WW Microwave Oven
Timing and light work but table doesn[t turn and no heat
Check the door safety interlock micro switches for fault or damage.
Apr 24, 2011 | Panasonic Microwave Ovens
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
Feb 24, 2011 | Amana ACO1860 Microwave Oven
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Shuts down
check control circuit , and thermal sensors, check every thing, may be touchpad,
Nov 13, 2007 | Kenmore 80883 Microwave Oven
Shuts Off after 22 seconds
Time to buy a new microwave as it sounds as if the control panel is defective. A new control panel for this micro will run about 95 to 120 bucks + labor depending on where you buy it. I happen to like slightly burnt popcorn as well!! Nothing wrong with thats, as they say great minds think alike.
Aug 25, 2006 | Panasonic NN-S933BF Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
