Question about Maytag Dryers
Loud noise when motor shaft turns - Maytag Dryers
    Sergeant:
    Champion:
  • 252 Answers
Check your blower wheel.
Posted on May 18, 2011
Motor making loud noise and Shaft not turning Is repair possible
The bearing or bush of the motor would be faulty. try to put some oil on the shaft.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 10, 2016 | Cuisinart Ice Cream Makers
We recently had an icestorm now my windshield wipers make a loud noise and wont work
If you turned the wipers ON while they were still frozen to the windshield you likely stripped the gears in the wiper's motor. They're likely only going 1/2 way because the wipers also got misaligned on the motor shaft, too.
You may get lucky and be able to REALIGN the wipers on the shaft.
Watch this video: https://www.youtube.com/watch?v=c-tR49oL1FQ
for an idea of what I mean.
GL,
TD
Feb 25, 2015 | 2003 Ford Explorer
Whistling
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
Jul 22, 2014 | Whirlpool Washing Machines
Well the belt cause a loud noise when it spinning out have to use max spin or clothe are still a little wet
During the spin cycle a loud noise is usually coming from the bearings. If you want to know whether it's coming from the bearings of the engine or the drum, you can remove the belt and turn first turn with the drum and then with the shaft of the motor. If the bearings are bad you can hear it and also feel it if you touch the motor and the drum
May 01, 2014 | Washing Machines
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
A loud noise from the motor, high pitch ound
Hello
The noise that comes from a motor like that is the bearing or bushes on the motor , it can just be caused from dirt on the drive shaft. clean the shaft and add some spry oil to the shaft, if the noise is dose not go away then you will need to look at replacing the motor.
Thanks
Jun 15, 2011 | Hotpoint Dishwashers
2003 yukon rear wiper motor wont work makes loud noise and no movement even after i changed the motor is this a switch problem
If it makes noise when you turn it on, the switch is working. So whats making the noise. If you replaced the motor, there isnt much else. Is the wiper arm tight on the shaft?
Nov 24, 2010 | 2003 GMC Yukon
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
1995 galant broken balance shaft belt
You sould replace the belt along with the timing belt. If it gets caught in the timing belt you will have MAJOR EGINE DAMAGE!
Jul 21, 2009 | 2005 Mitsubishi Galant
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
