Question about Daewoo DSP4210GM 42 in. Plasma Television
Whaere is the scart lead?
Could you please help just got a 42inch plasma daewoo tv from a freind not sure how old it is bue it says plasma dream digitalin top left corner we cant find a scart bit to plug the freeview box into?
    Scholar:
  • 59 Answers
Http://www.e-daewoo.com/products/owners_manual/DTS42(English).pdf
Please have a look at the above user manual from the Daewoo site. You may need to down load the Adobe PDF reader if you can't open the file. You can get that from this web site;-
http://www.adobe.com/products/acrobat/readstep2.html
I am not sure that this is exactly your model but one page of the PDF document , page 14 shows the connections at the back of the TV with no obvious SCART connection. So I think you will have to connect the two using a component video cable and the Left and right audio cables as show in the manual on page 28. or via an s video cable and right and left audio cables as show on page 30.
If the connections in this manual look about right for the connections on the back of the your TV set I would be tempted to take this manual printed out (or just the image of the back of the set page 14) down to your local TV shop with the Freeview box and ask them what cables they recommend you use to connect the set.
Also be aware that cables from these TV shops cost a fortune and you can probably buy the cables cheaper on eBay once you know which ones you need. Without seeing the freview box its hard to know what cable options that box offers you.
Regards
Posted on Aug 14, 2008
My bush 42 plasma tv has a snowy picture
Check all the input connections. Snowy picture cane be due to weak input signal.
Mar 09, 2013 | Televison & Video
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
After a weekend at a freinds house using his smart flatscreen tv and using a hdmi lead when i plug it back into my tv using a scart lead nothing appears on the screen please help
Ok, you need to hold the power button down for 5 seconds until it beeps once, this will revert back to standard definition.
Hope this helps
Aug 07, 2010 | Sony PlayStation® 3 (80GB) Console
What is the TV channel set to to play a dvds151 dvd player?
almost all Dvd players are connected to a television by either a scart or a HDMI lead.
When you plug the scart into the back of your television (make sure its in properly) then turn the power on. on your dvd player.
This should automatically come on as scart leads send a voltage up the scart telling the tv to change to that source/av.
If it is connected via a HDMI cable then if you look at the back of your telly it will tell you what HDMI input number it is. then all you have to do is press the AV/ SOURCE button on your remote to select that number.
Hope this Helps
Little Dish Fitter
Sep 01, 2009 | Daewoo DVDS151 DVD Player
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
Please help
you have to me a scart that needs to be pushed in correctly either hand or have you tryed another scart lead..
Mar 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
No video from dvd/receiver; getting audio; receiver is a amphion MediaWorks T-352; tv is a samsung 42" plasma; any help would be appreciated
What type of lead are you connecting it with?, a Scart maybe if so that could be your trouble, make sure no pins are bent, both ends of the lead, reconnect it and test if still a problem try another lead. Common fault with Scart.
Feb 18, 2008 | Televison & Video
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Daewoo DSP4210GM 42 in. Plasma Television Logo
159 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
