Question about Bosch 12" Compound Miter Saw 3912
I have a boch 3915 10 inch sliing miter saw and it won't power up. I have checked the outlets and they work with my other saws. Any suggestions? Thanks.
Kazong
  • 152 Answers
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Posted on Jan 13, 2008
  • 313 Answers
SOURCE: 10 Craftsman Compound miter saw
toolpartsdirect for parts diagram or dewaltsrevicenet.com
Posted on Jun 03, 2008
  • 313 Answers
SOURCE: Craftman miter saw
should be located at the pivot arm assy where close to the motor.
pranaclimbin
  • 50 Answers
SOURCE: craftsman compound miter
if its like my dewalt, u have to unscrew it before u canunlock the handle. try unsrewing it.
Posted on Dec 04, 2008
  • 384 Answers
SOURCE: How Do You raise the blade on a miter saw to get
Lift the Handle.
Posted on Aug 31, 2009
How do I fix the spring on the switch for a 10 inch ryobi miter saw? I can hear it rattling around and the switch won't work. Also plastic screws holding handle together are broken.
Hello Anonymous,
First locate the model number of your Ryobi Miter saw... then search Google for Ryobi Miter saw replacement parts... one result I got is below:
http://www.mastertoolrepair.com/ryobi-power-tool-parts-ryobi-miter-saw-parts-c-873_895_937.html
Try that link, select your Ryobi saw model and zoom into the provided drawings so you can locate the switch, screws, and spring (if needed). The part numbers are supplied and you can order them online easily on that same link... Then just repair your saw with the new parts. As you already noticed, the saw is easy to disassemble and get access to the parts for repair. Have fun and good luck...
RYOBI Miter Saw Parts
Mar 10, 2015 | Ryobi 10 In Miter Saw With Laser
When I try to start the saw, it bumps but does not start. The brushes look good.
clean the brushes holder unit and fit the car ban brushes check car ban brushes is content to armature and also check power cord and fuse.
Oct 11, 2014 | Hitachi C10FCH2 10 Inch Miter Saw With...
Why miter saw dws780 wont turn on
Have you checked the manual. My Dewalt Dws780 was not turning on, then I checked the manual and able to start it. There was some sort of plug issue with my saw but thankfully it sorted out quickly. I got this saw from this video recommendation.
Aug 13, 2014 | Dewalt DWS780 12-in Double Bevel Sliding...
Makita miter saw wontr turn on
make sure that your outlet is hot, once verfied that you have power going to the plug of the saw cord, verify that you dont have any breaks in the cord itself. once verified no issues with cord you can check for power at the switch, if there is power at the switch but not coming on, probably bad switch.
Aug 10, 2014 | Makita 10" Miter Saw LS1030N
I have no power
Since you mentioned that the saw is new, why not try calling the manufacturer. It's the best way to you could do for now.
May 23, 2013 | Hitachi C10FCE2 10" Compound Miter Saw
Miter saw won't start
It is a burned brush holder...new one cost $15
Nov 11, 2012 | Saws
My 10 inch mikita slide saw just quit working. I tested the trigger switch and it seems to be fine but the saw motor won't run. Does anyone have any ideas?
Try another tool in the same power outlet. It may have popped a breaker. Make sure the blade turns freely. Does the motor have brushes that should be looked at? Hope this helps!
Apr 16, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita Ls1212 works intermittently
Check the power cable. They could be broken or frayed and you are not getting enough power to it replace and then try to see if it works then. Make sure you buy the right size gauge for you machine
Apr 24, 2009 | Makita Tools 12" Compound Miter Saw -...
Bosch 12" Compound Miter Saw 3912 Logo
29 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
