Question about SmartDisk PhotoBank USB Digital Dr 80 GB Hard Drive
Smartdisk PB80. I have copied photos from an SD card to the Photo Bank. Memory indicates 70GB free space remains. Problem is I can't get my Computer to open PhotoBank to retrieve or copy files to my computer. I'm running on Windows Vista.
  • kenyatravele May 19, 2011
    Yes, it was helpful. I did use a different USB cable which helped. However, I got only error messages when I tried to go on PhotoBank site to download a driver. So I hope I don't have a problem again.
    Guru:
  • 1,833 Answers
Hi, According to your problem check the connector cable or replace it. Try to update driver & firmware.
Posted on May 18, 2011
How to put photos onto SD cards
In Windows, click on Start/Computer. A window opens showing all the drives connected to the computer. Under "removable drives" locate the SD card. Hover your mouse pointer over the SD card icon and it should tell you how much free space is on the card. If necessary, delete some photos or other data to make more space available so you can add the photos you want. If there's already plenty of space, try formatting the SD card in either ex-FAT or NTFS format. Then try copying the photos again. If the SD card does NOT in appear in removeable drives then the SD card may be faulty. Try a different SD card.
Nov 04, 2014 | Philips 6.5-Inch Digital Photo Frame...
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
My memory card appears to be corrupted and I can't access my photos. Is there a good photo retrieval software you can recommend that is both good and free?
For retrieval of photo media, especially on SD Memory cards I would highly recommend this program which is free for download. Just copy and paste this link into your browsers address bar, download/install, and run..
http://www.snapfiles.com/opinions/mjm-free-photo-recovery-software/mjm-free-photo-recovery-software.html
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
I was copying my pictures to my SD card , it stated that it was processing and now , all of my vacation and family pictures are gone. What happen and What can I do to get them back? PLEASE HELP!!!!
001 picture recovery is a photo recovery software for digital memory card. It can effectively recover lost, deleted, corrupted or formatted photos from various memory cards. It supports all memory card types. Free download from:
http://www.001-software.com/picture-recovery/
Aug 04, 2011 | Optimus DS-5080 Digital Camera
When im reformat my 1gb micro sd,my all data will be deleted...is there any chance to recover or back my deleted file coz of reformatt?
you can recover photos after reformat with asoftech photo recovery software, you can follow the steps below
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download asoftech photo recovery software
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your lost photos.
Dec 22, 2010 | SanDisk 1GB microSD Memory Card
How do I recover pictures from the camera's memory if there are no pictures on the memory card?
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this digital camera recover program called asoftech photo recovery from
http://download.cnet.com/Asoftech-Photo-Recovery/3000-12511_4-10913438.html?part=dl-10913438&subj=dl&tag=button
Install and open the photo recovery software, select the memory card, and click 'Start' button.
Jun 18, 2010 | Panasonic Lumix DMC-FS5 Digital Camera
I have a Smartdisk PB80 PhotoBank
I have a pb80, and I found that it would not read SD above 2 g.
It reads a 2 g fine, but not a 4 g.
I also have a reader with the same problem. I replaced the reader with a different model, and it works fine. Planned obsolence.
Apr 26, 2009 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
SmartDisk Digital Photo Bank Model#PB40
No, the problem isn't solved. I paid the $19.95 for your "premium assistance" which consisted of telling me about the SmartDisk warranty and advising me to contact the company. As my "problem" points out, "been there, done that." No response from the company. Your technician just went to the company's web site and read it to me. I had already done that, too. If your "technician" could have advised me about how to fix the device, or even how to get the company to respond, he would have been worth the $19.95. He couldn't and didn't. Needless to say, I'm still p1ssed off and $19.95 poorer.
Apr 21, 2008 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
Can photos that were accidentally deleted from a SD card be recovered
yes, you can recover deleted photos from sd card with sd card recovery software like asoftech photo recovery, here's the steps that helped me
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Apr 17, 2008 | Kodak EasyShare Z740 Digital Camera
SmartDisk PhotoBank USB Digital Dr 80 GB Hard Drive Logo
312 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
