Question about Intel Motherboard
My gigabyte H55-S2M beeps continuously when running 3D graphics games (I have GTS 250 card). The Nvidia app says temperature is below 60c which is ok. The computer runs like this for hours, perfectly, no problems whatsoever except this horrible beep.
    Genius:
  • 1,400 Answers
Hello
Check the CPU fan for proper operation. Check the case for proper air flow.Overheated CPU.
This is a heat related issue for the main processor.Clean the processor fan and heatsink area.
Also check the fan in your gts250 vid card for dirt or dust.I clean mine with a q tip.And a vacuum.
Posted on May 18, 2011
How to overclock Geoforce GTS 450
In the nvidia control panel you can overclock you're card. But there isn't much headroom on the card.
Sep 14, 2013 | Gigabyte GeForce GTS 450 - 1 GB GDDR5 -...
Trying to download a new driver for the Gigabyte Geforce Gts450 and none of the ones I've download seem to work. A couple have come up with not digitally signed and another said there was required files...
Hello chadster 79
We will start by going through my published guide entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!!
The section on Nvidia Graphics Cards applies to you.
The Nvidia website is the best secure place to download the drivers from.
Remember to insert the information in the spaces provided on the Nvidia website to get the best drivers for your graphics card.
chadster 79, thumbs up!
Let me know how it goes.
damnor01
Apr 09, 2011 | Gigabyte GeForce GTS 450 - 1 GB GDDR5 -...
Every high framerate game i play causes the graphics to stutter, i have a msi h55 motherboard, i5 quad core processor and 8 gig of ram. could you tell me what might be causing this problem?
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
Use my guide to install the latest drivers for your graphics card. It is entitled How to install Graphics Drivers, Nvidia and AMD Radeon!!!
Your computer components may be overheating, install as many fans as your computer chassis will allow. Use 120mm fans if you can, Cooler Master SickleFlow 120mm fans are Excellent.
The cooler you can get your computer to run the better it will perform and the longer it will last.
Download a program called Hardware monitor.
You will then be able to run this program in the background while you are playing your games, then exit the game and check the maximum temperatures.
CPU temps should not be over 65 Deg
Graphics Card Temps should not be over 70 Deg
The H55 computer mainboard is not really a gaming mainboard, it is more of a media setup.
If you keep every-thing cool I suppose you might get away with it.
You may need to give your mainboard an upgrade to P55, Socket 1156
Get a good make I prefer ASUS.
Happy Gaming, For the Win!
Thanking you kindly
damnor01
Jan 21, 2011 | BFG Technologies BFG Tech GeForce 9800GT...
I have Nvidia Geforce 9500 GT graphics card ...I recently bought my system...4 GB corsair ram....1 TB hard disk...400 W Cooler master PSU...Classic intel H55 motherboard...Still when play Gta or NFS hot...
How can I state this politely?
The Nvidia GeForce 9500GT is a definite step up from using Integrated Graphics.
No debate needed there.
But it only has 32 Stream Processors.
Think of Stream Processors as a 'Graphics Information Highway'.
They are essentially the lanes of the highway.
The more lanes you have, the more graphics information can be transferred from the graphics card to the Processor, and vice-versa.
Having 32 Stream Processors is like having a 'Bottleneck' in the road.
Equate that to a roadblock put up for road construction, where 8 lanes are dwindled down to 1 lane.
Traffic slows down.
This is seen when using intense games. Frame rates drop down, the game freezes, and graphics are poor unless on low settings. (Or not at all)
Here, take a look at Evga's version of the Nvidia GeForce 9500GT graphics card.
Read the Specifications at the bottom, watch the video.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4111742&CatId=3669
However!
A decent graphics card shouldn't 'Break the Bank'.
You don't need a $500 graphics card to slam those games.
You might want to look into an Nvidia GeForce GT 240 graphics card.
96 Stream Processors.
512MB of DDR5 graphics ram memory. (That's DDR5)
550MHz Core Clock
1340MegaHertz Shader Clock
3588MHz Memory Clock
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5516908&CatId=3669
Better than that?
Nvidia GeForce GTS 450 Superclocked.
1024MB of DDR5 graphics ram memory.
192 Stream Processors.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6655890&CatId=3669
For the above two graphics cards you need a decent power supply.
IF, the power supply you have DOES produce an honest maximum wattage of 400 Watts,
AND has at least 30 Amps on the 12 volt power rail. (Or 12 volt power rails), you're okay.
I would recommend an OCZ StealthXStream 2 / 600 Watt power supply though, when you can afford it.
It can produce over 700 watts if kept at a temperature of 48.4 degrees Celsius.
(119.12 degrees Fahrenheit )
Has FOUR 12 volt power rails that can supply up to 18 Amps EACH.
(Total of 72 Amps)
Has all the power cables you'll need, plus ones for the above graphics cards.
(Can handle them with NO sweat)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6491962&CatId=106
Not advertising for Tigerdirect. Just using them to show examples.
Regards,
joecoolvette
Nov 08, 2010 | Evga NVIDIA GeForce 9500GT,, PCI Express...
What is the best pc graphics card? for blu-ray and 3d.
This is the list of Nvidia Gfx cards that can support blu-ray and 3dvision
NVIDIA GeForce Graphics Cards
GeForce 400/300 Series GeForce 200/100 Series GeForce 9 Series GeForce 8 Series 3D Gaming Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GT 320 Desktop
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GTS 240
GeForce GT 140 Desktop
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 9600 GT Desktop
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS
GeForce 8800 GT 3D Applications Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GTX 295
GeForce GTX 285
GeForce GTX 280
GeForce GTX 275
GeForce GTX 260
GeForce GTS 250
GeForce GTS 240
GeForce 9800 GX2
GeForce 9800 GTX+
GeForce 9800 GTX
GeForce 9800 GT
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS
GeForce 8800 GT 3D Pictures Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
All GeForce 300 series Desktop
All GeForce 200 series Desktop
All GeForce 9 series Desktop
All GeForce 8 series Blu-ray 3D playback* Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
GeForce GT 340
GeForce GT 330
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 295**
GeForce GTX 285**
GeForce GTX 280**
GeForce GTX 275**
GeForce GTX 260**
GeForce GT 240 Notebook
GeForce GTS 360M
GeForce GTS 350M
GeForce GT 335M
GeForce GT 330M
GeForce GT 325M
GeForce GT 320M 3D Movie file playback Desktop
GeForce GTX 480
GeForce GTX 470
GeForce GTX 465
GeForce GTX 460
All GeForce 200/100 series Desktop
All GeForce 8 series * Blu-ray 3D playback requires compatible Blu-ray 3D player software from companies such as CyberLink and Arcsoft. Please continue to check the 3D Vision product home page for more details on Blu-ray 3D support.
** Blu-ray 3D GPU decode acceleration is not supported on these models. Please insure that your CPU is fast enough to handle video decode (a quad-core CPU recommended)-->
And don't know about ati graphic cards which has these features. i'm sure i have given you a satisfactory answer.
For further any help or to thank me you can mail me on my email Ejaz89@live.com
Aug 08, 2010 | Computers & Internet
I need help choosing a Graphic card ...
Man, trast me, the GTS 250 is way better than the hd 4870 one. on each section of the measures of performance factor, 250 beats the 4870. PhysX is the hardware utility for making the real world effects like the gravity , air factors, sea waves more realictic easily .
Apr 18, 2009 | HEC Group ACE 580UB 580-Watt Power Supply
Geforce 8600 gts drivers crash and recover moments later
Sorry for the bad news, but you've seem to have witnessed a graphic card meltdown...
During games, cards get quite melting hot! If there's a little problem or inefficiency in the card cooling system (Active Fan or Passive Airflow) Your card will simply melt a few little contacts, enough to produce what you saw or even worse!. (Basically just in the graphic 3D render portion of the board, thats why you could still see windows some times but Aero (3D) started glitching later).
If you wish, you can verify this at your own risk opening up your case and placing your finger on the free corner of your card and bending/arching it a little to the sides when windows or your games are running... It may restore contact at the melted away points for a few seconds for you to see, but won't repair it, you'll maybe see how images get better or worse with the bending, proving the meltdown situation.
Return your card if you can or buy a new one, before the crashes mess up your windows. Buy a new one from a good manufacturer and clad with an elaborated cooling system, if you plan to run 3D heavy games, stay away from the weird branded, cheapest or heavily discounted cards are usually the ones most prone to fail this way. If you go ATI, buy ATI made cards. If you go NVidia, buy BFG for example.
Jan 07, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Intel Motherboard Logo
107 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
