Question about Eureka Atlantis 2590A Wet/Dry Vacuum
When I fill the the container with water and attach it back to the steam vaccum the water comes out from the bottom without the steam vaccum being turned on.
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
When button is pressed, water does not come out of the holding canister. still seems to have suction, but water doesn't come out to rinse/clean carpet.
Please check the following with liquid in both tanks.
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Nov 22, 2010 | Bissell 9200 Upright Vacuum
Wear do you put the water
Inside the main tank is another container for clean water.
To fill it, lay machine all the way down. Lift handle and remove container. Take to sink, turn handle, and remove lid. Fill with hot, clean water. Replace and lock the lid. Place container back into tank and put handle down.
Sep 29, 2010 | Bissell 1699 ProHeat Clear View Upright...
My bissell steam cleaner will not spray any water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have the Bissell heat pro 2x 8920 and the water doesn't come out. The soap just mixes with water tank and the carpet stays dry
Jun 14, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Need video or large diagram instructions for what to put together
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ui
May 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I do not know how to operate are hoover steam vac
pull out water container, fill the inner "bag" with hot water and cleaning solution, (the dirty water goes outside of the "bag" inside of the container. First run, squeese trigger to wet area, leet sit for a minute or two the go back over it until you feel it has picked up enough of the water. It will still feel wet, but as long as it was not picking up any water when passing over the area, thats all you can do. run fans and open a window.
Jan 24, 2010 | Hoover F5886-900 Steam Vacuum
Leakage from eureka deep steam carpet claeaner
You will just have to take it apart to see if a hose is loose, came off, or is cracked.
Jun 14, 2008 | Eureka 2576A Steam Vacuum
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Eureka Atlantis 2590A Wet/Dry Vacuum Logo
93 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
