Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
Same station same code only working one way motorola 250
We have 4 units different brands(2 are pair, other 2 are from different sets each) but same station same code, the wo pair work fine with each other, the other two can call out but we cannot hear the response back to the Motorola 250 singles. Any suggestions?
  • 258 Answers
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Posted on Aug 15, 2008
I have an Italian portable a/c, from Olympia Splendid, model isss mio 2. I purchased a universal remote Digitech AR-1731 and it will not pair. Is there a code for my unit?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts. .
Jan 06, 2017 | Universal Televison & Video
Motorola h700c
Have you tried a soft reset of the unit?
Try uninstall and install again the devices/
Mar 16, 2008 | Motorola Mobility Bluetooth...
Can a Motorola talk about 250 talk to a cobra CXT 195. They can hear me from the Motorola I just cant hear them
Your code (PL code, interference eliminator, quiet call) is not programmed the same on both radios. The Cobra appears to be set to open squelch (no code). Set your Motorola code setting to zero (off). This should solve the problem.
Feb 18, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
I have a set of motorola fv700 talkabout radios. they wont transmit to each other. i checked the inter. elim. code. they are the same. and i have even turned them off. these are new radios. i know they...
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Aug 27, 2017 | Motorola Talkabout T5420 (14 Channels)...
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
Sep 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Here is a link to a list of older TalkAbout user manuals. Use the pulldown menu to look at various models. In general, most of them program similarly by using the menu button to select the feature and the PTT button to lock in the change.
May 26, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Problem transmitting
Hello jayhawkrx,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a Privacy Code or Quiet Code. The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on one of your radios but not on the other. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code 4 on the Motorola TalkAbout series actually corresponds to code A on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Mar 09, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola 250 manual
I was made to understand that the 250 together with 270SLK, 280 & 289SLK all came out sometime last quarter of 1998. To my knowledge, all share the same basic features. The only difference is that the high end models feature built-in VOX, available colors, power/battery condition indicators, some other frills.
Like you, I couldn’t find any manual for a 250 but the user’s manual for a Motorola Talkabout T-289 is available here. Since most features are presumably the same, you can probably try winging it from the 289.
Here and here are nice articles about the 250.
Hope that this be of some help. Pls post back if this is of any use to you or should you need further information.
Good luck and kind regards.
Nov 08, 2007 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
150 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
