Question about Hitachi CP-RS55 LCD Projector
I work in a school and one of the projectors has a yellow area in the centre of the projection. The lamp has been replaced ?
  • 20 Answers
Your Blue LCD Light valve is burned or has dust on it which blocks the blue color.
With RGB, the absense of blue (Red + Green) is yellow.
If you're lucky a simply cleaning at the light valves will solve your problem. Otherwise your looking $$ for a new LCD valve.
Posted on Nov 05, 2011
Yellow area on display about 2 ft. diameter. have replaced lamp and cleaned front lens. suggestions????
Sad to say many of these Sony projectors are now developing faults in the LCD panels. In your case, it's a problem with the blue one.
Replacement units are available, but they are very expensive and a nightmare to install. Given the fall in price of projectors, and the ready availability of high brightness LED lamped units now, your wisest move might be a replacement projector.
Alternatively, you could take it to your nearest authorized Sony service centre for a quotation, but you'd best be sitting down when you get the price. {:o(
Mar 27, 2015 | Sony VPL-ES2 LCD Projector
Hello! I have a DELL 1209S that the picture is wavering. Is it spring?! Some vertical lines almost invisible in the background are also perceived. What can it be?
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Dell 1209S DLP Projector
Red warning light
  • 2
  • 3
  • 4
  • 5
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Turn off on screen message
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | Dell 4310WX Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • 2
  • 3
  • 4
  • 5
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
The light shines yellow on the screen. Is it the lamp that's on its way out, or is it just a setting?
If the yellow area is mainly in the centre and not a well defined spot, then it's most likely the blue polariser plate that has been overheated by the white light over much use.
Sep 20, 2011 | Hitachi CP-SX5600W Multimedia Projector
Projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
May 06, 2010 | Hitachi EDX-3280 LCD Projector
Yellow tinged edges
Your problem is most likely your Blue and Green lens' inside the light engine. It's not something you can replace yourself. I worked for Philips for 14 yrs. repairing the LCD projectors the last 6 Yrs. Call philips and get the number of an ASC in your area that has repaired projectors.
Feb 14, 2008 | Philips Garbo Multimedia Projector
Yellow area in the projected image
Hello Media Man,
Looks like your projector has done it. Thats acommon trouble to ageing polirising lens, usually the blue. less blue, the green and red make up the yellowish image on the screen. The blue is bombarded with tremendous heat from the lamp and it fade and wash out. If its free, its worth replacing. Get quote for the poliriser; 2 pieces each color.
Good Luck.
Sep 28, 2007 | Mitsubishi ColorView XL30U Multimedia...
Hitachi CP-RS55 LCD Projector Logo
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
