Question about Hoover Vacuums
Hoover TurboPower 6200 Windtunnel runs louder than normal. Does this have anything to do with the roller brushes?
5 Suggested Answers
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
  • 126 Answers
SOURCE: Hoover Windtunnel not picking up as well
There is a height adjustment on these vacuums and they are set to adjust in the "handle up" position". It will appear that the adjustment is doing nothing when the handle is up, but the setting will take affect when the handle is lowered.
You can check the brush length with a pen or pencil. Turn the machine over so that the brush is visible and run the pen or pencil flat across the bottom plate. Any where the brush is extending outward, your pencil should contact the bristle. If not, then the agitator should be replaced.
Also, check to make sure that the agitator is rotating freely and that the filters and bag are allowing for adequate suction. The machine will only pick up if the air flow is sufficient.
Posted on Mar 23, 2008
Agent Don
  • 310 Answers
SOURCE: How to replace power cord on Hoover WindTunnel upright vacuum
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=517499
How to replace power cord on Hoover Windtunnel...
Posted by SaxTeacher on Apr 15, 2008
The cord on my Hoover Windtunnel upright vacuum is damaged from having been run over while vacuuming. I purchased a replacement power cord, agitator brush, belt, and filters from the Hoover web site.
I have installed the new brush, belt, and filters. I'm ready to install the replacement cord, but I can't figure out how to access the interior part of the vacuum! I tried removing many different screws but none of them seemed to give me access to the necessary area. Any help would be appreciated!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
Depending on where the cord comes out, you may want to check the owner’s manual for the exploded view of the cord area. Usually the cord comes out of the handle and there should be handle screws to release the existing cord and when you replace the cord mark the wires so that you will replace the new cord in the same manner. If it comes out of the body of the vacuum there are recessed screws that will let out into the vacuum to replace the cord. You don’t want to exceed the repairs cost to the price of what you paid for it. The decision should be yours, example: if the repairs costs are $200.00 and you paid $279.99 then @ that point you would have to decide if the repair costs are worth or do you want to pay the lower cost of repair and continue on. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 07, 2008
  • 294 Answers
SOURCE: I have a Hoover TurboPOWER 7300 Windtunnel V2-belt change
1. Remove the 4 screws holding the bottom plate.
2. remove roller and old belt
3. install new belt on motor spindle first and then on roller.
4. pull roller, stretching belt, set into roller cavity.
5. turn roller by hand to center belt.
6. reinstall bottom plate.& screws
Posted on Feb 28, 2009
kevin_getz
  • 1026 Answers
SOURCE: My Hoover Dual V Windtunnel has suction but the
Take the lower plate off of the unit and check the belt for breakage. also, if it isn't broken, are there any obstructions between the belt and housing?
Posted on Jan 29, 2010
Hoover wind tunnel not picking up properly
My turbopower 6200 does not seem to be picking up. The beater bar I don't think is working?
May 01, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Vacuum gets louder
take the belt and roller loose then turn it on .if the noise is gone then the problem is in the base.disconnect the hose and try that.remove all the filters.check the brush roller and see if it turns freely remove all strings and carpetstrands from the ends of the roller.look at the belt and see if there are any burn marks on it.if its a eureka they tend to get loud
Apr 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How do i install belt?
every Hoover I've had has two screws on the bottom that you remove.  Then you lift off the cover and you pry out the brush roller. The new belt goes with one end on the motor shaft and the other end on the humped roller part on the brush roller.  Good luck it's a bit of a struggle but you can do it.
Apr 04, 2009 | Hoover U5081-930 Turbopower 3000 Bagged...
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
Feb 26, 2009 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Jan 08, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Vacuums Logo
315 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
