Question about HP Compaq Presario V3016US Notebook
Lan driver xpsp2 Intel pro/100vVE network connection driver for xpsp2
    Scholar:
  • 88 Answers
The best way to obtain the correct driver is to go to the manufacturer's support website.
Click here to go to the Intel support website, then choose the correct Operating System version and select driver.
Download and install the driver.
Hope this helps you.
Posted on May 18, 2011
I lost my lan driver
The Dell E210882 motherboard has been used in the Dell Dimension 3000. Thus you can try the Dell site for the XP driver. Start here: http://www.dell.com/support/drivers/us/en/04/Product/dimension-3000 and expand the section for network drivers.
If you have a different OS, try the Intel site since the onboard LAN is the Intel Pro/100 VE hardware. The Intel generic drivers are here: http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Network+Connectivity&ProductLine=Intel%C2%AE+Desktop+Adapters&ProductProduct=Intel%C2%AE+PRO%2f100+VE+Desktop+Adapter . Use the drop-down menus to select your OS and drivers if you want to shrink the list below (left-hand side).
If the on-board LAN has failed (it happens), get a PCI ethernet card. Then disable the on-board LAN in the BIOS. Usually that can be accessed by pressing Esc, F1, F2 or F10 on startup. There should be a splash screen telling you which key to press. If you get to the Windows login or Start Screen try again.
I hope this helps.
Jan 10, 2013 | Dell (E210882) Motherboard
I need help . my 82801DB ICH4 - PRO/100 VE Network Connection (PH: Intel 82562EM) was deleted when i reformatting my computer .. what would i do? what site can i find that file
You can download the LAN driver from the Intel WEB site. Go to this WEB site to download the driver you require.
May 09, 2011 | Computers & Internet
My pc crashes when I start a wireless connection using the computer wireless button. Network card is Intel Pro 2200BG wireless LAN. Have reinstalled the driver with no success.
try this...
1. download the updated driver
2. go to the device manager then uninstall the wireless driver
3. restart your computer then reinstall the driver
4. restart your computer for the last time and the driver will be installed properly
Jan 14, 2011 | Intel PRO/Wireless 2200BG 802.11g/b
Can't connect to the internet new hard drive installed, windows XP pro installed when checking hardware : says ethernet controller driver - not installed. tried finding it on the installation CD, get a...
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Oct 25, 2010 | Microsoft Windows XP Professional
I have a IBM thinkpad R40, i upgrade to xp professional from windows 2000, i have a problem with the LAN which always display no connectivity, i have installed the LAN driver downloaded to the IBM website,...
http://www-307.ibm.com/pc/support/site.wss/MIGR-54046.html
start here,determine witch of the two options you have in yours,intel pro 100 VE network connection or intel pro 1000 lan adapter then download and install according to instructions good luck,aloha from maui todd0708
Oct 22, 2009 | IBM ThinkPad R40 2681
Hi, i accidentally deleted my intel pro wireless using the add/remove button when clearing up my computer. Now the wireless connections icon in the network connections section has gone and i can only...
The drivers are located at the Dell site at:
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Intel+PRO%2FWireless+2200BG&cat=sup&x=9&y=6
Copy & paste the entire link in your browser
May 02, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
XP does not recognize the Intel wireless network adapter
Dell has a known problem with driver conflic the best remedy is to right click on my computer click on property open hardware uninstall the driver there and restart the conputer but first make sure you download the driver from intel and burn them on a cd then when you reinstall you won't have to try to figure out if everything is downloading also in security make sure that you allow this site so that all the drivers download.
but most of the time if these driver are on a card that is micrsoft certified it will be in the driver file and will reload automaticly when you restart the computer after uninstalling and it should elimenate the driver conflic.
Apr 13, 2009 | Intel PRO/Wireless 3945ABG Network...
Network Card
Yes the network card is the same ethernet card. If your intel pro/100 is onboard try to re install the driver from the motherboard drvier. Check also in the manager device it the network device have a complex to the other device. Follow this, Click START then RUN type DEVMMGMT.MSC then enter check if the network adapter have a yellow question mark. If you found the network adapter right click and uninstall it.and click the ACTION and click SCAN FOR HARDWARE CHANGES. After the installation finished try to connect to the internet. If still the same even you input the correct ip in the network configuration. Buy a new LAN card it's not expensive, because usually the onboard lan is easy to damage or not working properly you can installed and configured it but you cannot connect to the internet.
Apr 15, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
System Crash
Hi
Intel 2200BG is known to cause this and similar errors when Wireless Application Protocol (WAP) encryption is used. The problem has been around since 2004 and new OS Drivers should fix this.
I recommend you download and install latest Windows Drivers (appropriate for your Windows Version) for Intel 2200BG Adaptor.
If this cannot be done, then setting your wireless to Wired Equivalent Privacy (WEP) encription (though less secure) will minimise these error conditions
NB: Google "w22n51.sys" for more info.
Regards
Mike
Mar 27, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
HP Compaq Presario V3016US Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
