I have a alpha cd24c heating is fine but when i turn on hot tap the boiler fires up for a couple of min then cuts out i have checked the fault finding section in the manual and it said there is a fault with the pump or restricted flow but both seem fine
3 Suggested Answers
SOURCE: got a Alpha HE CB33
Problem is normally the hot water flow switch -
Posted on Jan 11, 2010
burty681
  • 56 Answers
SOURCE: Boiler Alpha CB24. No hot water at taps unless cen...
its diverter or the flow switch
Posted on Jan 20, 2011
Boiler not running smoothly
needs tune up change filter and nozzle and check electrodes are clean with no build up and clean out chambers
Oct 10, 2016 | Heating & Cooling
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Heating & Cooling Logo
126 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
