Question about Air Tools & Compressors
My Devilbiss EGA-503-390F suction feed spray gun won't spray any materials with a viscosity greater than water. I purchased this gun in March 2010, and it was fine. I have cleaned, chnaged the needle packing and lubricated the gun, but the problem still exists. It is as though the suction is low from the 8 oz. cup. I have tried opening the needle to full open, and air pressures from 20 to 80 psi, and it makes no difference.
  • 2 more comments
  • kenneth sharkey Apr 15, 2012
    Jim i am just wondering if you could let me know how to change the Needle Packing i have brought a repair kit and i am not sure.
    Thanks
  • Roy Lane
    Roy Lane Sep 10, 2014
    Probably neds a larger needle valve say a 1.8mm or 2mm I had the same problem. If you have too much air oressure the air will move too fast to pick up the paint and air is all you will get. 25 to 35 PSI is plenty.
  • Roy Lane
    And as you thought if the paint is to thick it won't pick it up, even a gravity feed won't work if the paint is too thick or you have too much aur pressure.
  • Roy Lane
    Just go with a larger needle valve and nozzle
    Problem Solver:
  • 14 Answers
The EGA-503 only comes with one set of air cap and Nozzle Size (!). And this is suitable for light and precise touch-up jobs. If you want to spray something heavier, then you would have to change the set-up, i.e. larger nozzle. But for EGA-503 only 390 (air cap) and F (nozzle) are available. Theoretically you could check for the predecessor EGA-502 which had different set-ups, incl. nozzles called "EGA-608-G" and "EGA-608-E". However, they are only limited available and you would have to change needle and air cap too. This makes the whole thing probably too costly.....
Michael
info@sprayfinishingstore.com
Posted on Jun 02, 2011
Testimonial: "Okay. I guess I will purchase a new spray gun with a larger orifice. Thanks, Jim Goewey"
The trigger sticks on my DeVillbis quartcup spray gun. I have to push the trigger back open to stop the spray.
There is a spring inside the gun body which pushes the trigger back. Check this.
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Apr 29, 2011 | DeVilbiss (DEVTGC545) Quart Suction Cup
Air pressure out through the suction tube of liquid my spray gun - DeVilbiss jga 558
If your getting air down the suction pipe your air cap isnt tight enough or its the wrong one.
Oct 21, 2010 | Air Tools & Compressors
Unit does not draw from bottom cup
Both are gravity type spray guns, i.e. they cannot draw from a bottom (suction, siphon) cup.
Jul 25, 2010 | HVLP 2 DeVILBISS Auto Paint SPRAY GUNS...
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
I HAVE A CVI DEVILBISS AND HAVE GOT AIR LEAKS BEHIND THE TRIGGER ANY IDEA'S. JOHN
If a knurled round nut is attached to it remove it and a leather seal as a replacement will last for a decade if properly cleaned everytime
Jan 26, 2010 | DeVilbiss CVi? Suction Spray Gun/Cup #...
JGA Siphon feed The Gun Pulseates with fluid running through it
The tip is dirty and plugged try cleaning the gun is spray gun cleaner. If you would like more information just post here and I will answer.
Sep 24, 2009 | DeVilbiss Air Tools & Compressors
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Air Tools & Compressors Logo
988 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
