Question about Whirlpool Kitchen Ranges
Whirlpool super capacity 465 mod sf365pegw 0 ser rj1911677 cannot control temperature. varying temp controller while cooking can send temp up or down no matter which way you turn. have replaced board and sensor to no avail. thanks
  • 1 more comment
  • rllrsk8 Aug 14, 2008
    sorry, i failed to mention that this problem relates to the oven temp controller.
    again, just to clear up any misunderstanding:
    oven will not hold temperature. changing setting causes erratic swings in temperature.
    do not understand recent suggestion to replace shorted switch. again, this is not a burner problem.
    Master:
  • 623 Answers
Change temperature controller
Posted on Aug 14, 2008
  • 813 Answers
U have go witha a professinol service person
    Master:
  • 521 Answers
Switch problem for sure the circuit is short at the switch end,get it replaced.
  • tech expert12 Aug 14, 2008
    better call a service technician to check the full unit.such a problem should not arise after changing a board.in ur case it cannot be rectified without manually checking were the problem lies.
    Genius:
  • 3,422 Answers
If you cannot adjust the burner temperature your burner always heats to "high" when it's on--regardless of how you set the burner knob--the switch contacts are shorted closed. Check the circuit for any other grounds, then replace the switch.
  • Whirlpool Master
  • 19,396 Answers
If it happens on one burner only it can be the burner.
Whirlpool super capacity 465 LCD display and power lights went out
I assume your talking about the ignition for the oven - the display doubles as the computer controller for the oven ignition and temperature control. Its likely you need a new LCD display board, its commonly known as the PCB or OCU.
Apr 05, 2013 | Kitchen Ranges
Oven won't work. Display says "LOC" Top of range works
Try pressing Cancel then press and hold Cancel and Cook and Hold together. Hold the two keypad buttons for 3+ seconds. This toggles on and off the Control Lock for several models of Whirlpool ranges, including the WDE150LVB0.
If this doesn't help, please add a comment with your range model. The Super Capacity 465 is series of ranges, not just a specific one. The model number is on the range inside the drawer on the rim of the unit. I'll be glad to check if the control lock for your model uses a different combination of keys. Many manuals for Whirlpool products are available here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Nov 23, 2011 | Whirlpool Kitchen Ranges
My Super capacity 465 is not cooking at the right temp. It is about 25 degrees off. is it a thermalstat?
most likely yes... there is a thermostat probe that probley needs to be replaced... however 25 degrees is not to far out... some of these units you can get into the control settings and calibrate... if nobody else has ever worked on unit normally there is some literature in the control area behind the panel that is for the servicer and it should tell you how to get into setup and adjust/calibrate the temperature and offsetr it by 25 degrees... you are just reprogramming unit... if that doesn't help then get a new thermostat... good luck to you ....
Jan 12, 2011 | Whirlpool Ovens
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Sep 24, 2008 | Gaggenau EB 270/271 Electric Single Oven
Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
Mar 16, 2008 | Whirlpool SB160PEE Gas Single Oven
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kitchen Ranges Logo
227 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
