I HAVE A CANON IC2020I INDICATING A PAPER JAM. CAN NOT FIND ANY JAM - THE ERROR LIGHT LIT IS JUST ABOVE THE TOP LEFT SIDE OF THE FROM COVER. ALL SENSORS CHECK GOOD. ?HELP PLEASE
  • 823 Answers
Try unplugging the machine and then press and hold the power button for 30 - 45 seconds to clear the memory of the machine. then plug it back in and turn it on. if this does not clear your paper jam error, try downloading the Canon Tool for windows from their website to troubleshoot your machine. here is a link to all of the software and/or drivers available for your model
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2016_2016i_2018_2018i_2020_2020i_2022_2022i_2025i_2030i/imagerunner_2020#DriversAndSoftware
Posted on May 18, 2011
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
CANON IC2020I INIDICATES A PAPER JAM LFT TOP OF THE SIDE DOOR. THERE IS NO JAM AND ALL SENSOR CHECK GOOD
try removing the p/j of second tray from the board after removing the back cover.I am sure the error is from the second tray sensor.in order to this error solve it u have to remove the second tray unit from the copier and then try to blow it throughly.
May 20, 2011 | Canon imageRUNNER 2020i Black and White...
The triangle light is lit on the panel. What does
tooner goes to low or paper stucking any where in paper path..check for both ur problem will be resolved
Jul 30, 2010 | HP LaserJet P2015dn Printer
Canon pixma ip1980 service error 6000.. it flashes 3 flash...indicates paper jam but there's no paper on tray... pls help? What's wrong with my printer?
you need to open the printer. it has sensors around it. the one that you need to check is in the left side when you are facing the printer. the one that is sensing the graduated circular part. Remove the left cover on the side. then remove the sensor with a philip screw driver and clean it. then place it back and turn your printer on. I hope to be of help to you. Let me know if this works. I did it on mine.
Oct 06, 2009 | Canon Office Equipment & Supplies
Paper light keeps blinking and won't print I have paper and it's set as default printer
It keeps blinking because there is a paper jam. Open the front cover and take out the toner/drum and see any jammed paper. Also, you can open the back cover, pull the paper guide down to see the rollers.
If the above does not work, take off the front cover. Pull the tabs on the side. Pull out the toner/cartridge. Look for a blue tab on the top, and you need to slide that from right to left. Put everything back and see if this solves the problem.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Paper jam
Use mirror and flashlight to look down paper feeder from the rear, gently pull paper toward the rear. An index card can be fed from the front to the rear to push paper out by turning the gears you see on the left side inside the front cover. Be careful not to force anything.
Jun 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Nov 15, 2008 | Canon imageCLASS D880 All-In-One Laser...
Canon i9900 blinking three orange / jam
I had the same problem with my i9900 - 3 orange flashes on the the error light (Paper Jam) and yet I could slip a sheet of paper in and it would feed through OK. My problem is that the SPRING on the PAPER SENSOR had come off, leaving the sensor in the where it would be if there was a paper jam.
You have to REMOVE the main cover of the printer to find and fix this problem You have to find all of the release points (look for triangles on the plastic covers) where you insert a small tool/screwdriver to (1) press 1 release each side & remove the 2 silver end panels, (2) press 1 release to remove the control switch & carefully disconnect the two connectors inside. Start with the triangle rlease on the lower front left of the main cover, then 1 on the left side, 3 on the back, 1 on the right side, and finally 1 on the lower front right side and gently lift the whole cover off.
You can then look inside with a flashlight from the top rear just behind the left side paper feed roller and see a small switch which pivots when paper is fed through the printer. Feed a sheet of paper and see if the spring is returning it to the normal (no jam) position. I used a long pair of tweezers to reach inside and slip the spring back into its normal position which is behind the small slot on the far right side of the switch. No pictures, but it should be intuitive where the spring should go. Once reinstalled, the switch will move back to the normal position and your paper jam should be fixed.
This SAME MECHANISM is also used in a number of other Canon i & ip series printers so this general approach to fixing this in other models could be the same - (1) remove the cover, (2) locate the switch, and (3) put the spring back into the correct positiion.
Aug 31, 2007 | Canon i9900 InkJet Photo Printer
19 people viewed this question
k24674
jasbo
jasbo
