Question about NorStar M7208 Corded Phone
I have a norstar m7208 phone and I want to use it as a standalone normal phone set, is it possible ?
  • NorStar Master
  • 2,460 Answers
Nortel Norstar M7208 always reads "Calls For You". What can i do to clear display?
This is Caller ID log
FEATURE 812 View Call Log
FEATURE 813 Manual Call Log
FEATURE 815 Deletes Call Log Items
To have no log see your office administrator or call your local tech to De-program your phone from the system log.
Nov 28, 2012 | NorStar M7208 Corded Phone
NorStar M7208 - How to remove global ringing?
This is tech side of programming and not Admin, if you don't know config password or how to program then call a tech.
If you do know then:
First find out what line #, do F*0 then press the button and note the full number on the display.
i.e. Line 5 in programming is Line 005, 025 or 031 depending on software version.
Sets/LineAccess/LineAssignment/Show line ***/Change to Appear Only or Not Assigned.
Jul 25, 2012 | NorStar M7208 Corded Phone
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
My Norstar M7208 phone wont ring. We've moved into a new facility and the ringer does not work now.
Is set relocation on?
If not then probably what has happened is that the new station port does not have ringing programming of the old port.
if you know how to do this go into riging programming of the set and activate it
Aug 03, 2009 | NorStar M7208 Corded Phone
Won't generate tones from keys when connected
Any other phones on system with the problem?
DTMF or touch tones are generated through the trunk card(s) of the sytem problem. Chances are there may be more then one phone that has a problem.
Also on the outside of things, just try calling the same number from a different phone on the system, and if possible try using the trunk/line that you did with the m7208 in question, same problem? If yes possible trunk issue. If no, then try another phone where the problem set is plugged into.
Another thing you can try is call another service that uses a touch tone menu, using the phone in question, see if you have the same problem.
May 11, 2009 | NorStar M7208 Corded Phone
Doesnt ring
My BT Meridian compact does not ring after it powered down in a thunder storm. The lines flash and can be answered as normal just no ringing sound
Mar 14, 2009 | NorStar M7208 Corded Phone
Re-set date and time on display
Have you tried:
Feature **23646 password 23646 (if you phone admin hasn't changed this) and then select set day& time then change there
Feb 23, 2009 | NorStar M7208 Corded Phone
Nortel M7208 Swapping phone equipment but keeping the extension
There is a built-in feature called Set Relocation. Check with your system administrator to make sure this feature is set to No. Then you can swap phones without a problem. Good Luck!
Aug 05, 2008 | NorStar NT8B30 M7208 LCD Speakerphone -...
Norstar M7208 display screen garbled
Increase the contrast of display of ur phone it might fix the problem
May 13, 2008 | NorStar M7208 Corded Phone
NorStar M7208 Corded Phone Logo
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
