Question about Microsoft Windows XP Professional
Start menu and task bar is not responding for a mean while after i turn on my computer.
    Problem Solver:
  • 12 Answers
Please follow the given steps to relaunch the Start Menu and Taskbar:
1. Press Ctrl + Alt + Del or Ctrl + Shift + Esc to bring the Task Manager.
2. Go to Processes TAB
3. Find explorer.exe and select it
4. Click End Process (Button at Bottom Right Corner)
5. Click File Menu and Select New Task (File-->New Task(Run))
6. type in explorer and press ok
Posted on May 19, 2011
Start tast bar disappears
Right click (hit right mouse button) on task bar and click to lock task bar and uncheck hide task bar. If you cannot right click on time before it disappears move pointer to the bottom of screen and it should reappear. Than follow above steps. If all else fails restart computer clicking on the F8 key repeatedly until start menu comes up , choose safe mode and when the computer starts up your task bar should remain in place, follow above steps to unhindered it permanently and reboot the computer it will start back up in normal mode and your task bar should be "fixed"
Feb 05, 2013 | Lenovo ThinkPad T410 Notebook
Task bar at bottom with font size on it has gone
The task bar is an important part of the Windows experience. Not only does it contain a variety of information including what time it is and how much battery life is left it's the way most Windows users open programs and documents. As such, the task bar disappearing is a stressful thing, but fixing this problem on your own is possible.
Auto-Hide Sometimes you may think your task bar has disappeared, but it's really just been set to "auto-hide." Move your mouse to the bottom of the screen and see if it pops up automatically. Then check all four sides of the screen. If the task bar was simply auto-hiding, disable this feature by right-clicking the task bar, clicking "Properties" and unchecking "Auto-hide the Taskbar." b> Reboot b> If your task bar disappears, and auto-hide isn't the culprit, the first thing you should do is reboot your computer this fixes the problems in most instances. Only one problem: because your task bar disappeared you can't access the "Start" menu in order to shut down the computer. Instead press "Alt," "Ctrl," and "Delete" at the same time and press "Restart" in the window that pops up after doing so. Your computer should restart, and in most cases your task bar should come back when it restarts. b> More Options b> If rebooting doesn't fix cause the task bar to reappear, your computer might have a problem starting explorer.exe, the program that displays the task bar and desktop icons in Windows. Press "Ctrl," "Shift," and "Esc" at the same time to bring up the System Manager. Then click "File," followed by "New Task (Run)" and type "explorer.exe" in the dialogue box that pops up. You now have your task bar and desktop icons back. Reboot to see if they stick around after rebooting. If not, repeat the process in the above paragraph. When you have you task bar back click "Start," then "Programs," then "Accessories," then "System Tools" and then "System Restore." Restore the computer to a time when everything was working fine by clicking that date on the calendar. Reboot to see if this fixes the problem. If none of this brought back your task bar permanently it may be time to run a repair install. Change My Task Bar b> In Windows operating systems, the taskbar shows your currently active windows and programs, shortcuts to your favorite programs, the time, your volume control, active programs and the "Start" button. You may want to change the taskbar so it has a different look or to customize it to suit your needs when using your computer. Windows XP users have fewer options than Windows Vista or Windows 7 users, but all operating system owners can make changes to the taskbar.
Right-click in your taskbar. Left-click on "Lock the taskbar" if it is currently checked. Otherwise, click back onto the taskbar. Click on any empty area of the taskbar. Drag the taskbar to the position (bottom, top, left or right side of the screen) you desire, and release it. Re the taskbar by moving your cursor to where the taskbar ends. Your cursor will change to a two-way arrow. Left-click and drag the taskbar until it reaches the you want. Move your cursor over the series of separator bumps between the Start button and the Quick Launch menu, and the Quick Launch menu and the active programs section of the taskbar, to alter the of the Quick Launch menu and the active programs area. Right-click the taskbar, and left-click on "Lock the taskbar" once you've completed the changes you wish to make. b> Change Taskbar Options b> Right-click on the taskbar, and left-click on "Properties." Modify the taskbar settings so that it appears the way you like. You can decide whether to show the Quick Launch menu (a series of icons for your most commonly used programs), to show thumbnails for your active programs in Windows 7 and Windows Vista and to group similar active programs, and to automatically hide the taskbar or to always have it on top of other windows. Click on the "Notification" tab in Windows 7 or Vista to modify the way the notification area to the far right appears. Stay on the taskbar tab in Windows XP. Hide inactive icons, and decide which information to show, including the clock or the volume, power and network icons in Windows 7 and Vista. Click on the "Customize" button to specify which programs or notifications should always show, never show or grow inactive with disuse. Click on the "Toolbars" tab in Windows 7 or Vista to specify which toolbars you wish to see in the taskbar. Your options will vary according to the programs you have installed on your computer but may include the Quick Launch, address bar and links toolbars. Click the "Apply" button, then "OK" once you have made the changes you desire. Hope this helps.
Jan 16, 2013 | Computers & Internet
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
I have QuickBooks Pro 2008. When I'm starting the program it gets as far as asking for the password, then that's it, the program never actually starts up. The icon is displayed in the active task...
Try using Alt+TAB to see if it is actually there, but pushed off the screen.
You may need to reinstall the software to get it to fully work correctly.
You can also right click the task bar on the bottom and choose Windows, Cascade.
Oct 05, 2011 | Intuit QuickBooks Pro 2008: Windows
Tool bar moved t right and is large
Right click on the task bar (I assume you mean the bar that is typically at the bottom of your desktop?)
Make sure "Lock the Task bar" is not checked
Click on the border of the task bar
drag directly from where you clicked to the bottom
Adjust height accordingly
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
My computer is getting slow when right button of the mouse is selected
The Virtual Memory on your system may be low and could cause your mouse clicks to respond slowly. Also you virtual memory size is directly related to your RAM size. For Better functionality, your Virtual memory should be 1.5 time the RAM size (150% RAM Size).
To check if the memory is the cause of your problem, right click your task bar (Task bar is the lower ribon at the bottom of your screen), click on start task manager. on the Open window, click on the perfoemance tab. If you have used up more than 90% of physical memory usage, your system will perform slogishly.
To check the Virtual Memory, right click my computer Advanced ( or Advanced system setting if you are using win7), on the performnace menu, click on settings, check to see if the "let Windowns choose what's best for my computer" is selected if not select it. click ok and close all the open windows.
Jan 05, 2011 | Computers & Internet
It was suggested that I find my task bar in order to correct the
probably you just messed up the settings ...if you still can click on start ...just right click near the user name ..and properties will appear..click on it ..and you have the settings choice for both the task bar ..and the start menu ...I really hope you will handle it ..
if not ..just try to make a system restore task ..and assuming that you no longer have the start ..just click on my computer ..than in the side task bar (left ) you will have tasks and other places...there look for control panel ..and click on it ..
be sure the control panel is on the category view..(it has a task in the same left task bar) ..and in the category view click on performance and maintenance ...in this moment you have a second task in the left bar named system restore..click on it ...and follow instructions..choose to restore to an earlier point ...than choose one highlighted date in tha tab ...that you know for sure the computer was fine ...and proceed..If you are lucky and the system was not affected by another kinda virus...and is not a case for reinstallation...your system will restore itself after the reboot to an earlier setting stage ..
May 09, 2010 | Toshiba Satellite A135-S2276 Notebook
I have lost my Menu Bar and have tried going to the Control Panel
try using your menu key on your keyboard. its next to the Ctrl key, that will bring up your start menu which shuld also show the task bar. right click on the task bar and click on properties. make sure "auto hide Task bar is not checked. and lock task bar. you may also have lowered it below your view. try moving your mouse pointer down at the bottom of the screen and see if your pointer turns into an arrow., if it does hold the left mouse button and move it up untill your task bar shows.
Icons and start upmenu bar absent
explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
Jun 08, 2009 | Computers & Internet
Start Task bar not showing
Press the Windows key to open the Start menu, then right-click the start button and choose properties.
Next, go to the task bar tab and
1. Uncheck auto-hide
2. Check keep task bar on top of other windows
Dec 11, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
