Hallo my name is efren I have a problem in RLC IF I HAVE UN CIRCUIT RLC SERIES R=50OHMS L=5..3 C=3900 PF 1/2PI SQART(L C) EXAMPLE SQART( 5.3*10^-3) (3900*10^-12 ) = 0.159 CAN YOU SHOW ME HOW TO RESOLVE PLEASE I CANT FIND THE 0.159
  • 483 Answers
If C = 3,9 nF
L = 5,3 mH
f= 1/6,28/sqrt(L*C) = 220 Khz
If you had problem with this solution, you could give additional question.
Thanks.
gylacz
Posted on May 20, 2011
My Frigidaire electrolux dishwasher model # FDB2310LCC0 trips a pf code 40minutes into the cycle and it is not the circuit breaker. how do i correct this problem?
Good Morning Doria, thank you for allowing me to assist you!
Typically PF means power failure and you should be able to start a cycle. Unplug the unit or flip the household circuit breaker. Wait about ten minutes and then turn the unit back on. If the error code continues to display, I would suggest contacting a professional to accurately diagnose and repair it.
Best of luck!
Oct 07, 2013 | Electrolux Frigidaire Professional Series...
Sorry I do not speak English well. C120 pac my team. PF mark on the screen and turn on all lights. not working I have to do Thanks for your time
This unit stopped working and displayed the PF code for Probe Failure. I fixed it by removing 6 screws for the panal and 4 screws for the back panal and removing the 5 screws and 1 screw holding the ground wire off the silver box with the circuit board in it then I un plugged the little plug for the 2 probes with the black wires in it and replugged it in and wiggled it several times with the unit pluged in (be carefull not to get shocked I recomend someone with electrical experiance do this for you) the plug must get corroded but this fixed my unit.
Good luck.
Sep 13, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Code p1445
P1445: CHECK PF SENSOR HIGH VOLTAGE TO PCM
Continuous Memory Diagnostic Trouble Code (DTC) P1445 indicates that Self-Test has detected a PF sensor circuit input above the maximum.
Possible causes:
PF shorted to VPWR.
PF open circuit.
PWR GND open circuit.
Damaged purge flow (PF) sensor.
Damaged PCM.
Jul 24, 2011 | 1996 Mercury Cougar XR7
I have generac c 5000 series, that is 5000 watts . can you give me the equivalent watts given into Kva?
philliprabay,
This is the formula The conversion of W to KVA is governed by the equation KVA=W/(1000*PF)
For example 1500W/(1000*0.83) = 1.8 kVA (assuming a power factor of 0.83)
Thanks for using FixYa and for the great rating.
hardrocko
Sep 28, 2010 | Honda 6370C - Parallel Power Kit For ...
The initials "pf" come on and prevent our fridgidaire dishwasher from continuing it's cycle. What is the problem?
"PF" generally means Power Failure. First, be sure that the door is latched tightly. Vibration may loosen the latch causing the unit to stop. Also check your circuit breaker. Flip it to the "tripped" position and firmly back to the "on" position.
If this model is an "electronic" unit (for example uses a touch pad for programming), there may be a loose connection somewhere in the wiring prior to or at the junction box under the dishwasher. The electric "noise" generated there might confuse the dishwasher's computer. Best to have an electrician look at this.
Aug 10, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Dryer won't turn on
Using a resistance meter, check the resistance of the motor that turns the dryer. If it short circuit (0 ohms) or open circuit (50ohms or greater) then you'll need a new motor.
There may also be a open circuit to the motor than inhibits it from functioning correctly.
An appliance serviceperson should be able to troubleshoot the motor and any other circuit faults. Perhaps a new (or slightly used) dryer is the cheapest solution.
May 10, 2009 | Dryers
Dryer kicks off circuit breaker, pf code is on dryer. now won't let me do anything
pf is for power failure. sounds like You may have a short somewhere. Be careful of electric shock.
Apr 21, 2009 | Dryers
64 people viewed this question
 Grubhead
Grubhead
