Question about GPS
I have a new unused Tronic T4X Battery Charger for 12v cars/motorbike. When this is plugged into the mains supply, the red standby light is illuminated, but when the 'Mode' button is depressed, it remains in standby mode. It will not charge. Do I bin it and buy another???
  • 374 Answers
SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
Posted on Jul 17, 2007
CodeMaster
  • 11 Answers
SOURCE: It does not turn on, remains in stand by mode.
I cannot be COMPLETELY sure of this so be careful, but doesn't the PS3's board cater for both types of power supply and therefore a step down transformer is not needed? Check the labels on it just in case, but be wary I CANNOT be certain of this...
Posted on Sep 26, 2007
  • 213 Answers
SOURCE: My Samsung LCD LA32R7 won't
you have a bad power supply.
Posted on Jun 11, 2008
  • 13 Answers
SOURCE: Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Posted on Jul 01, 2008
SOURCE: navman won!t charge from in
Your Navman will not run in car unless the output on the charger is 1000ma or 1a. you need to buy a genuine charger, motorola phone chargers do not have the output to run the unit
Posted on Aug 26, 2008
Haier LE50H3280 will not power on
If all power supply voltages are within specs, then it just might be an issue with your main board,.
If PS board has a relay make sure that it is also working.
Oct 18, 2016 | Haier Televison & Video
How do i charge the battery on a 1992 honda shadow vlx 600c
First check the battery voltage using a multi-meter set to DC and volt range if reading is below 12V battery has probably one dead cell get a new one, if between 12v and 13V battery should be OK to charge. Remove battery undo negative lead first then positive. Please do not use a car charger or any other charging device that has an output greater that 1 Amp you will fry the battery. Charge the battery for as long as possible. Recheck volts across the battery if above 13V refit battery connect positive lead first then negative.
Start your engine, when warmed up check the voltage across the battery terminals it should be well above 13 volts. Increase the revs and watch the meter the voltage should increase to about 14.5 volts. This shows the battery is being charged. Please remember batteries on bikes only last a few years and short rides do not put enough charge in your battery. Buying and using a motorcycle Smart charger does help. I use a CTEK XS 0.8 12V Motorbike Battery Smart Charger & Conditioner. You get a small wiring harness that fits to the battery with a rubber connector that connects to the chargers plug. This unit will help to keep the charge in the battery topped up.
Jan 10, 2015 | Honda Motorcycles
How long does it take a tronic 150w power inverter to be fully charged.and how long does it last after being disconnected from charging?
This device is meant to convert DC power from a car battery and similar devices into AC mains power suitable for running small appliances. It is not intended to be an energy storage device. Once plugged in, it does take a few seconds to reach peak output and will remain active a few seconds after input power is removed. This is due to the slow collapse of the magnetic field generated by the internal transformer that feeds the AC output. You'll notice this same effect in your laptop charger if it is equipped with an LED indicator light letting you know it is energized.
May 08, 2014 | Power Tronic Computers & Internet
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
Jun 28, 2011 | Black & Decker Pivot Plus Cordless...
Instructions for a Tronix T4X Battery Charger
Use this link www.kompernass.com/pages/index.php?page=1,2,1,1&lang=en , scroll down through multiple products, yours is there.Please note, I have this product and it would not let me select a charge mode, stuck in standby, until I raised the battery voltage above 7.5v with a freinds charger, then worked fine. Hope this helps.
Jan 04, 2010 | Electronics - Others
Spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jul 18, 2009 | Vector 3 Million Candlepower Rechargeable...
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
Sansui dvd recorder SAN0901
turn the power on. to get rid of the red light you need to press the timer/rec button on the remote until it turns off. the red light means it is programed to record.
Dec 01, 2007 | Sansui VRDVD4005 DVD Player/VCR
GPS Logo
544 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
