Question about Acer SYS C2Q2664GB320GBDVDX2W7P VM480GEQ8400C MiniTower System Intel Core 2 Quad Processor Q84 (PSV7503004) PC Desktop
Computer overheats to 120 degrees celsius, then shuts down, idles at 65 degrees. Have replaced core fan and paste on both the heat sink and the graphics card under that fan. Do you have any other ideas? Thanks Michael Houston
    Problem Solver:
  • 28 Answers
Did you put it properly? check if the fan is running.
Posted on May 18, 2011
Why the card cage fan is working faster in dell precision 380 without getting slower?
Don't try to slow down the speed if you don't know the temperature from your processor or your motherboard. Look on the web for a monitor program to see if one of them is getting real warm Like above 60 degrees Celsius. Then your fan will work as hell.
If the computer is a bit older, perhaps the cooling paste, between the processor and the cooling body on the processor is dried. Only use the correct cooling past, and not anything else. Don't allow the processor to heat up above 65 degrees Celsius, because it won't live long after that.
If you do have a monitor program, you could slow down the fan, without any risk.
Jun 15, 2014 | Dell Precision 380 Workstation Pentium D...
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
CPU keeps overhreating.
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 24, 2013 | ASUSTeK COMPUTER ASUS P8Z68 DELUXE/GEN3 -...
Emachines t5212 overheat message then shuts down
Three causes of ovheating:
1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed air and clean the dust out of the computer.
2) A Fan not working. Make sure the fan inside the Power Supply where you plug the power cord in works. Also there is a fan that sits on top of the CPU and Heat Sink. Make sure it works. Normally the system will give you an error message if the fan is not working.
3) Thermal Paste - The Thermal Paste around the cpu and heat sink has dried up or is too thin to keep the unit cool. Apply a fresh coat of Thermal Paste on the CPU and Heat Sink.
May 09, 2012 | E-Machines W Computers & Internet
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Mar 21, 2012 | Computers & Internet
Cpu overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 25, 2012 | Gateway GT5012 PC Desktop
Overheating cpu
Problem could be you need to repaste heat sink on processor.
Over time the thermal paste becomes brittle and no longer takes heat away.
Repaste processor and heat sink using thermal paste.
Also adjust fans to high speed always in bios.
Dec 07, 2011 | Gateway GT5662 Desktop PC
What part of my computer is defected if my computer will shutdown after 15 secs?
check your cpu fan first normally it's the fan.can give you more things to check, like memory stick but if that does not work write back and I can tell you also the power supply fan may be dirty or bad these are the most common thing you can find. and if you see a lot of dirt on the fan that is most likely your problem.
Mar 23, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Processor Overheating
It is important to use good quality thermal paste like Arctic Silver. You only need a very small amount on the heat sink. Too much is as bad as none at all. You care just trying to create a thin layer of thermal paste to fill in the tiny gaps between the processor and the heat sink. If this does not help an aftermarket heat sink with more fins and a better fan might be needed.
Mar 18, 2009 | Intel D865GVHZ Motherboard
Acer SYS C2Q2664GB320GBDVDX2W7P VM480GEQ8400C MiniTower System Intel Core 2 Quad Processor Q84 (PSV7503004) PC Desktop Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
