I have just put my memorry stick into the usb port but the light on the stick has not come on.it appears to not working ,what can i do? so therefore the stick does not register on my computer
    President:
  • 2,047 Answers
Try using a different USB port or a different PC. Once the USB is not recognised there is nothing that can be done about it as it cannot be accessed. Although there is a probability that the USB port has been disabled hence the inability to access the USB. If it works on another PC then the USB is still in good shape. First you have to determine if it is the drive or the port which is bad.
Hope this solution has been helpful?
Posted on May 18, 2011
    President:
  • 1,607 Answers
It is either your USB stick has a problem OR your USB port has a problem. Try it on another computer to find out for sure.
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
The usb ports on my acer 5250-0650 do not work when a memory stick is installed.
Have the ports ever worked? Have you opened the computer icon to see if the flash drive is being detected- but maybe not auto-starting? Also, if a drive is inserted (Windows system), you ought to see the "safely remove hardware" icon appear on your taskbar, near the clock. Clicking on the icon ought to show you the drive by name & drive letter.
Lastly, right-click Computer>properties>device manager>expand disk drives>if your flash drive is shown here, highlight it & uninstall the device. Remove the flash drive, then reinsert it. Windows will reinstall the driver & this may allow it to recognize the drive again.
Let me know?
Cheers
Feb 25, 2015 | Acer Computers & Internet
Computer does not reconize mermory stick
Either the port on the computer is bad or the memory stick is bad.
If you are using a usb port to plug in the memory stick, try another usb port.
Try plugging the memory stick into another computer to see if it works or if it is bad.
Jun 02, 2012 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My usb port wont reginize my usb stick
try putting your USB stick in the port provided at the back side your PC !!! if it doesn't work try in your friends PC if it doesn't work there then your USB stick must have failed!!
Jun 15, 2011 | Computers & Internet
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
Have a memorrie card fr my pitures but need t know how to put on compurter
You have to use a memory card reader (you can get them on ebay or at Best Buy), or use the cord for the small camera usb port to your computer usb port. Your computer should automatically recognize it when you connect it. Hope this helps.
Mar 14, 2010 | Cameras
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
USB PORTS
does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Feb 01, 2009 | Averatec 3200 Notebook
Card reader not working
Try putting your memory stick on a usb port on the back of the cpu. It may work. Usb ports on the front of the cpu and card reader may not work with all memory sticks
Dec 17, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
David Payne
David Payne
