Question about Kenmore Refrigerators
The lights on out Kenmore elite model 79577553600 refrigerator do not go out. This happened a while ago so I took the bulbs out. I waited a few weeks then put the bulbs back in. They worked fine for a while but now are staying on. The button on the door doen't turn the light off.
    Master:
    Sergeant:
  • 385 Answers
The button on the door is bad and needs to be replaced.
Posted on May 18, 2011
Lights in my kenmore refrigerator, freezer on bottom, burned out. I purchased two 60w bulbs and replaced them. I plugged in the refrigerator and the lights were on. Then a couple of minutes later,
Hello Sharon;
My name is Peter. I am a retired field service refrigeration technician.
You can not put normal house hold appliance bulbs in appliances. There are special bulbs for refrigerators, clothes dryers and close washers.
The bulbs are usually available in the local market and marked; "Refrigerator" and Freezer".
You may have a bad door switch. But, I am more prone to go with the wrong service bulb.
Your Friend,
Peter, Baltimore, Maryland, USA
Nov 16, 2014 | Kenmore Refrigerators
How to change light bulb in Kenmore refrigerator serial no. 4A31214613 ?
Open freezer and reach to the back of the plastic cover over the light. You'll feel a gap in the back center of the cover. Gently pull forward and the cover will drop down and pull to the back to fully remove it. Once you've removed the cover you can unscrew the bulb, which you can use to make sure you purchase one like it and most hardware stores, such as Ace or Home Depot. Reverse the removal instructions to install light and cover. Light should turn on once you've screwed it in.
Jul 22, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio 596 73503201
This happened on my side-by-side. There is a damper at the inside top of the refrigerator compartment that was failing to open to allow cold air in. I took the cover off and propped open the damper while I ordered the part and waited for it to arrive. Problem solved and hope to keep it running another few years.
Nov 13, 2013 | Kenmore Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
My kenmore Elite Trio lights didn't go off, it burned the light assembly in the refrigerator part. The bulbs turned dark and it melted the assembly a bit, the cover won't stay on. can I install a whole...
This will possibly fall in the class of models that were under recall. My advice is to contact Sears and the CONSUMER ALERT Remove your lighyt bulbs and prepare for a disgusting attempt for settling this. I am not telling you you this for any good rate or a bad rate. LG and Maytag made these for Sears and the name then changed to Kenmore Elite Trio. I would like you to visit my web page and do a little reading of our posting's here at Fixya over the past couple years. Wish I had a solution but feel it is my responsibility to inform you. Thank You for Understanding, Sea Breeze
Click Here=> APPLIANCE CONSUMER ALERT
Nov 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
201 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
