Question about Oki Electric Industry B430DN Laser 30PPM 2400X600DPI USB-p-o-e 32MB Dupl PCL5E 120V Printer
Oki B430dn problem 173:fatal error 050914 this is the falut message on display could you inform what this means thanks
  • 628 Answers
SOURCE: fatal error 173?
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
Posted on Aug 22, 2009
SOURCE: Error code 173
Thanks, The cable was not plugged in right. Solved now.
Posted on Sep 22, 2007
  • 152 Answers
SOURCE: I have a OKI C5500N, keep getting the message
1. Remove All files that were installed before 'fatal error' using 'Printer Util.exe' or similiar file available in your CD.
2. Install software 'Dial-A-fix'. (Dial-a-fix is a collection of 'known fixes' that have been compiledover the past year that really knock out some serious Windows problems....)
http://www.download3k.com/DownloadLink1-Dial-a-fix.html
3. Run the 'Dial-a-fix.exe' Software and select 'Fix Windows Installer' & 'Empty Temp Folder' options and click 'Go' button.
4. Restart your computer, run the your printer CD, you should have no problem. (don't connect the printer/device until the cd Setup prompts you to)
Posted on Nov 10, 2009
lafalot
  • 152 Answers
SOURCE: Hi I have a Oki
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Posted on Feb 03, 2009
SOURCE: My oki printer b430dn is flashing 380 paper jam
Hi
You have to look under the cover remove the black plastic cover, Remove in the left side by sliding the litte plastic tab in to the mittele and gently pull up, when it is loose in the left side slide it on to the mittle and it will go of in the right side too, Now remove the next black plastic cover, it's all black with at little "sharkfin" i the center, Just pull genltly upwards, and under there is the "380" It is at little tab, just wrikele it a few times. Now just assemble the printer an you are good to go
Posted on May 17, 2010
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Error 173 050914
Error 173 indicates an problem with the fuser / heater unit.
Jan 06, 2014 | Oki Electric Industry B410D Laser 30PPM...
ERROR 173 050914
Low fuser Temperature Error - Replace fuser or thermistor in the fuser - per Oki Svc Mnl
Fuser error. Replace fuser or if no-go, Main board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 27, 2011 | OKI B4600 Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 173?
Aug 20, 2009 | OKI C5150n Led Printer
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
Jan 27, 2009 | OKI C5100n Laser Printer
Error code 173
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center.
Sep 20, 2007 | OKI B4300 Led Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
Oki Electric Industry B430DN Laser 30PPM 2400X600DPI USB-p-o-e 32MB Dupl PCL5E 120V Printer Logo
6,098 people viewed this question
Top Oki Electric Industry Office Equipment & Supplies Experts
Tony
Roger Binsfeld
Victorman
Victorman
Are you an Oki Electric Industry Office Equipment and Supply Expert? Answer questions, earn points and help others
