Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
How do you change the typing laguage with a shortcut on macbook pro?
    Sniper:
  • 63 Answers
Go to system prefs/keyboard/keyboard shortcuts/keyboard and text input and check the boxes related to input sources and/or
  1. Open System Preferences and click International to display its preferences.
  2. Click the Language tab.
  3. In the Languages pane, drag your preferred language to the top of the list.
  4. Restart your Mac or log out and log back in to apply the language throughout your system.
Posted on May 18, 2011
  • Scott Connely
    Scott Connely May 19, 2011
    thank you so much - i will try this, it was driving me stir crazy having to navigate to the top of the desk to to change it all the time
  • rebecca curry May 19, 2011
    you are welcome let me know if it works out for u
Command s not working
An errant keyboard shortcut could be the cause. To check this, go to System Preferences, then Keyboard and click the shortcuts tab/pane.
Cheers.
Mar 21, 2014 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Macbook pro shift key opens preference pane each time pressed...:-(
Go to system preferences and keyboard shortcuts, u should have enabled shift keyfor that perticular option
Oct 02, 2013 | Apple MacBook Pro with 17" Display
"." shortcut macbook pro
It can be done, though this workaround doesn't function exactly the same as on an iOS device.
- In "System Preferences" find "Language & Text" and select "Text"
- Add a new rule where " " (double space) is replaced with ". " (period space).
-Enable "Symbol and Text Substitution"
-Check this new rule
Jul 04, 2013 | Computers & Internet
Macbook pro problem
Put the installation cd in your drive, and boot while holding down the C key
then open up "Disk Utility", and choose repair permissions
Oct 17, 2012 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
MacBook pro trackpad too sensitive
You can change the settings for the trackpad under the system preferences type in trackpad into the search box and you will be able to adjust it from there. Hope this helps.
Dec 06, 2011 | Apple MacBook Pro Notebook
Type @ on keyboard but it type
change it from control panel \ keyboard laguage
May 30, 2011 | ASUS Computers & Internet
Cursor and keys are unresponsive tryed 2 check if it was number lock witch its not
There has been a known issue with the first key (any key) of a Macbook Pro, not responding when typed and Apple appears to have addressed this with this software update for the Macbook and Macbook Pro:
Run the Macbook Pro Software Update v1.1 and the Macbook, Macbook Pro Keyboard Firmware update v 1.0 per this link:
Keyboard Issues with Macbook Pro
Let me know if this helps.
Regards,
-Mactechtrainer
Mar 24, 2010 | Apple MacBook Pro Notebook
Delete key on macbook pro won't work
you may have inadvertently set up a keyboard short cut on the delete key... go to your system preference app in the dock. Then select keyboard shortcuts... if you select "default" at the bottom of the window it will revert to the factory shortcuts and eliminate any you may have accidentally created...
Hope that solves your delete issue...
K
Jul 21, 2009 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
128 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
