Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an understanding
I've built several electronic pieces throughout the years. I even made an O2/Fuel meter that retails for @$200. I built 2 for about $11. (A little more considering I bought several resistors, IC chip sockets, boards, and LED's- Was going to make a lot of them- plus, cheaper in bulk) Like I was saying, based on the research on the net, it appears the RCA flyback is bad. I desoldered it and noticed the discolorations on the flyback and a gray/brown area off center on the board where it was attached. As a kid, I used to fix cordless phones (one of which had the board broken IN HALF). I'm also familiar with the use/operations of diodes, resistors, capacitors, transformers, reprogramming automotive PCM's (made my own "dump" program for reprogramming EECIV Ford by using two trashed computers for their plugs and making a J4 to do it) and a lot more. When it comes to TV's and how to make them work- yeah, I don't have an overall understanding why mine will not come on. That's particularly the reason I posted in the first place-
    President:
  • 4,402 Answers
So your tv will not turn on.
go here for advanced help
Posted on Oct 03, 2008
I lost the Power supply for a Bell Vista 200
If you have several other Vista 200s (like in an office) you may get the specific voltage\amperage\and connector design from another power adapter. If you have that info there are many retail electronic stores that sell universal power adapters that may fit your needs. The owners manual may also designate the required voltage\current.
Aug 26, 2016 | Power Computers & Internet
Trouble codes 93 buick lesabre
The first thing you have not checked is fuel pressure.
The pressure could be low, or the fuel filter could be clogged.
It takes more fuel to run the engine in the first 5 minutes until it warms up than under normal conditions.
The codes mean the sensors are not giving the computer the readings they should, but it does not always mean the sensors are faulty.
If the engine is running rough, or the fuel mixture is lean, the sensors will show that.
Code 44 is O2 sensor reading lean which may be true.
Code 33 is MAP sensor reading low vac which may also be true.
Another possible cause is the coolant temp sensor may not be telling the computer the right thing. If it tells the computer the coolant is 200 degrees and the engine is cold, you won't get enough fuel thru the injectors.
Feb 04, 2013 | 1993 Buick LeSabre
Engine light still on after replacing all o2 sensors i have a 2000 grand vitara
what codes are being set? several things can cause codes to set for O2 sensors and several things can cause the engine light to come on.
Jun 20, 2012 | Cars & Trucks
Moter ideles rough ,using lots of gas,dies when put into gear.
Earl! You could have bought a new car! Ah, but you must love this Ford truck, it's obvious from the never- say- die parts list. How long has this project been going on? If you plan on finishing it yourself. here's my thoughts: Invest in a good scan tool (about $150-$200), a good compression tester ($40), a vacuum gauge ($15), a multi-meter (your choice-a useful one starts as low as $20, a digital volt-ohmmeter (multi-meter) designed for auto electronics is desireable), and last, maybe a fuel pressure tester to round out the list (about $40). Maybe you have all or some of these already. They are all good diagnostic tools you will find very helpful in getting to the root of your problem. The place to start is with the scan tool. Look at trouble codes, look at live stream data. Both will help you a lot. Do a compression test. Find out the internal condition of the engine. New parts are good. Now make them work.
Jun 14, 2012 | Cars & Trucks
Tamron 200-500 mm f5-6.3 "lens not attached"
This lens lacks the electronics to communicate with the camera. You need to set the aperture to its smallest setting (as you've done) and switch to the manual exposure mode (turn the mode dial to M). You'll get no exposure assistance from the camera's light meter. You can use a separate light meter and/or adjust the exposure by reviewing your pictures.
Mar 09, 2012 | Tamron 200-500mm f/5-6.3 Di LD IF Lens
Casio Privia px 130 One of the keys (e4) sometimes playes at full velocity even when pressed lightly. It happenes vary regularly which means I can no longer rely on the key playing softly. It is...
One of the two contacts for that key is not working. This could be dirty or damaged contact. They use a conductive rubber pills that the key presses against circuit board traces. One contact makes before the other and this is how velocity is sensed. Unless you are adept at this repair, I would recommend you take it in for repair. Chances are any part cost is negligible... mostly labor to open and access the contacts for cleaning. Clean ONLY with 99% isoprophyl alcohol and Q TIps... VERY GENTLY.
Jul 02, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Our pool guy, who admittedly says he's not an expert on pentair products, says our control panel is shot! It is only 2 years old..I have a hard time believing such an expensive product would only last 2...
I have to agree that someone is definitely looking for Christmas cash! The full retail from the Manufacturer (MSRP) is only $650.00 and you can locate this part online from anywhere from $288.00 top $359.00. Labor should be 1 -1.5 hours to install. Our book rate at WeFixUglyPools.com is $535.00 installed for this part. You might consider calling around or ordering the part and having someone come out and just charge hourly for the install.
Pentair Warrants their heaters and heater parts for a period of 2 years, so if you are within your 2 year period, you are in luck! There is an exception to this, however. If you have built the pool recently, or purchased 3 separate pieces of equipment (i.e.; Pump, filter and heater) then you will find that your warranty on ALL your Pentair items is extended to 3 years from the manufacturer. If you have 3 pieces of Pentair Equipment: Call Pentair Tech Support and ask them to e-mail you document P3-160L.pdf (or click on the link provided).
Several things can cause a circuit board to go bad: electrical surges, moisture, or rodents. It is always better to have someone out that understands the heaters and can fully diagnose your failure, but it is great that you though enough about the price presented to see advice elsewhere...now take some of the money and put it in your own Christmas Stocking!
Dec 09, 2010 | Pentair Control Board - 42002-0007s
High fuel consumption. only 200 miles per tank
it has gotta be the o2 sensor, map sensor, or the mass air flow meter.............. these are the main inputs to the computer that controls the fuel control....let me know how that works out please
Dec 08, 2009 | 2004 Acura MDX
Where is the air mass sensor(air fuel sensor) on 1999 toyota 4runner sr5 3.4 6cylinder. I see a pre cat sensor and post cat. Are there more
Underhood (several versions)
Electronic engine control system component locationsLand Cruiser with 1FZ-FE engine shown
Electronic engine control system component locationsLand Cruiser with 2UZ-FE engine shown
Electronic engine control system component locations1998 T100 with 5VZ-FE engine shown
I hope help you; good luck (rember rated this help)
Aug 26, 2009 | 1995 Toyota 4Runner
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
