Question about Samsung CLP-600N Laser Printer
I am working on a Samsung CLP 600n. The message is "install transfer belt". The owner purchased a new belt, and it has the same message, The printer has less than 10k prints. It will print in Diagnostic mode. Test prints look good. Yellow and Magenta solids are perfect, Cyan has a slight Quality issue but not bad enough to change.
  • lcummings6 Aug 01, 2011
    No this does not help. The doors are closed correctly. It will run test prints in diagnostic mode, The Color bars look good and solid. When you take it out of Diagnostics you get the message again.
    Lee
    Guru:
  • 610 Answers
Try to re-seat the the transfer belt and make sure it is tightly in place. The "install Transfer Belt" warning usually means the system doesn't "see" the transfer belt. This is a sensor problem. Try opening the side door and shut it. Press the handle (not sure if its called a handle but the part you use to ope this side of the printer) in further than where it normally sits, check if the message switches off. I think its a sensor problem but sometimes its not very accurate and you have to make sure it knows the side is shut.
Hope this helps.
Posted on Aug 02, 2011
  • 670 Answers
Please make sure that you close the lids and doors in the proper sequence like before closing the toner cartridge door make sure you close the lid above it. Once you've closed the doors in the proper sequence the message should disappear.
Hope this helps!
Posted on Aug 01, 2011
Transfer belt
Try to take out transfer belt and reinstall. You might have to tell the machine that a new transfer belt has been installed.
Sep 09, 2013 | Samsung Image Transfer Belt...
My samsung clp-600n laser printer is missing the network menu, how do i find it when the menu goes from setup to information and not network!
Go to Samsung Download page and read the manual. See also the Software tab on the same page and install the appropriate SyncThru soft for your operating system. Dan
Sep 20, 2011 | Samsung CLP-600N Laser Printer
Samsung CLP-600N displays message - engine fuser low heat error. Machine is out of warranty.
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Aug 10, 2010 | Samsung CLP-600N Laser Printer
Invalid transfer belt error on Samaung CLP 600N
This error can arise when the door on the right-hand side of the printer, the part you open in order to replace the toner cartridges, is not correctly closed. Close the top right-hand section first and then close the door on the right-hand side firmly (slamming it if necessary) and then check that all edges look correctly aligned. That should solve the problem. Incorrect shutting of these parts has always been the cause of this error on our Samsung CLP-600N laser printers and we have several of them.
Mar 23, 2009 | Samsung CLP-600N Laser Printer
SAMSUNG CLP-600N YELLOW CARTRIDGE DUMPS INK
Did you replace the cartridge with a genuine samsung cartridge or is it a refill or remanufactured cartridge?
Gremlin11
Dec 11, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP-510 Engine Fuser Low Heat error
I would purchase a new colour printer, Brother make some good stuff now and put your toner on fleabay.
1 747results for colour laser printer
Apr 21, 2017 | Samsung CLP-600N Laser Printer
Installation of the transferbelt on samsung clx-3160fn
take drum out,carefully pull transfer belt which sit on top of drum.see how it is install remove and slide new one in.
Oct 05, 2008 | Samsung CLP 300 Laser Printer
Samsung 600N transfer belt
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
Apr 20, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP600 - wants me to install a transfer belt
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Mar 31, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP-600N Laser Printer Logo
74 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
