Question about Microwave Ovens
Hi, I have a Bosch fridge/freezer KGV3120 GB/01. It works normally, but after a while(when it reaches the thermostate temperature) it stops and does not start again. When switched off for a while it starts again. I heard the problem is a sensor built into the fridge wall failing. The sensor (NTC? - measuring evaporation temperature I think) is built in for other markets and can be safely by-passed in the UK climate. I need to identify the correct wires to the sensor so I can disconnect them, then solder them to each other with giving zero resistance. For that I need a wirering diagram. Can you help me? Regards, Claus M. Christiansen.
  • 2 more comments
  • Claus M. Christiansen May 18, 2011
    There is no fan that blows cold air from the freezer into the fridge.
    I suppose you mean the defrost timer is located inside the freezer in the back, I find no plastic panel there.
    It looks as if it is not my fridge/friser you are talking about. Mine is a KGV3120 GB/01.
    Please advise me.
  • Claus M. Christiansen May 25, 2011
    My Bosch KGV3120GB/01 is different, it has 4 wires (2 blue, 2 brown) rather than the 3 (1 black, 2 brown).
    A fellow made a solution to his problem (see "Problem and solution" below). That and your input gave me the solution idea.
    I could see that Dark Brown/Light Blue wires go as one cable into the fridge and that the Light Brown/Dark Blue as another cable.
    I cut the Dark Brown with Light Blue and joined them at the plug to the PCB, and left the Light Brown and Dark Blue as they were.
    That fixed my fridge problem and it is now running fine. It switch off around 5 degrees and on around 7 degrees with the "1- > 5 adjustment dial" on 1 (the temperature can be adjusted by the "1- > 5 adjustment dial").
    This fix indicates that the Light Brown/Dark Blue wires must be the connection to the temperature sensor.
    "Problem and solution":
    I have a Bosch KGV3120GB/01 and am experiencing exactly the same non-cooling problem - where we have to power it off and wait before switching it back on in order for it to re-cool.
    Like Sele, I have found 4 wires (2 blue, 2 brown) rather than the 3 (1 black, 2 brown) that others have found I saw the earlier instructions from Jan.
    Q: Which 2 wires (of these 4) need to be joined together?
    Jan? Sele? Anyone?
    Thanks for any input!
    Jan
    Well, with a little trial and error, i've answered my own question!
    Indeed the two blues show little to no reistance between them.
    But, joining the 2 middle wires together (Dark Blue with Dark Brown) seems to have done the trick! The fridge keeps on running and cooling, and the 1- > 5 adjustment dial still does it's job. Magic!
    My Bosch KGV3120GB/01 fridge/frizer no automatic re-start problem fixed by a combination of your input, the link to solutions you gave me, and a little creative thinking.
    My Bosch KGV3120GB/01 has 4 wires (2 blue, 2 brown) from the PCB plug at the right hand side (closest to the on/off switch) behind the panel in top og the front of the fridge.
    Hi Andie,
    Where can I give you the 4 thumbs up?
    Regards and thanks,
    Claus.
  • 710 Answers
Hi Claus,
You may have gotten this twice. My internet connection went down just as I was posting it.
I didn't find a wiring diagram, but did find a forum where someone gave instructions on how to short the sensor. I'll describe how to do it in case you can't access the website. Here's the web address: >>>> http://www.reviewcentre.com/vt100228_start0_orderasc.html
1. Take the panel off by removing the 2 screws.
2. Look at the back of the panel and you will see a white plug with a large black wire and 2 brown wires.
3. With the panel hanging from the fridge, locate the brown wire that is closest to the fridge. Wire this one to the large black wire with an insulated wire.
The large black wire is the power wire. By wiring that with the brown wire closest to the fridge, you will bypass the sensor.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 19, 2011
  • 823 Answers
It a defrost timer that you are talking about. The fridge has a cycle that is handled by a defrost timer. Thats what keeps the coils from freezing solid in the freezer part and it also blows cold air from the freezer into the fridge to keep things cold on that side. Without the timer, it won't complete the cycle. Turning it off and on again will make it work for a little while, but it will stop again without the defrost timer. You can find the defrost timer in the freezer back behind the plastic panel. Take everything out of the freezer get a screw driver and remove the panel to uncover the coils that look like baby bottle brushes. You can find the defrost timer by looking for a part that looks like a fat nickel. it has 2 - 3 wires on it. All you do is unplug your machine, cut those wires and take that part to buy a replacement timer. Most appliance stores have them. they are pretty standard. it should cost you about $ 22 american for the part. To replace it, just connect the wires and put wire caps on them and then plug the machine back in.
Posted on May 18, 2011
American fridge freezer power on lights on in both sides. Set to maximum cold setting but freezer temp is only just lower than fridge, which is not as cold as it would normally be.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 10, 2011 | Bosch Microwave Ovens
My fridge is warm doesnt cool down the things inside only the chilly colder box is cold and it freezes down the meat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 19, 2011 | Bosch Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Fridge section is warm freezer is cold fan not working can hear the motor from thr fan but fan is definately not spinning. BCH KGN33V00GB
Hello Tonytonz953,
I understand that you are needing to change the fan on your refridgerator. The fan is loacted in the freezer section and has an outlet that blows in to the fridge compartment. You can order the fan at the following link http://www.ransomspares.co.uk/parts/search/fan-/bosch/fridges-freezers/kgn33v00gb%2f06/b/c/m/ this is the cheapest on that I could find and the cost is 75.85 pounds.
Thank you for choosing FixYa.com
Justin
I need a manual for Fridge Freezer BOSCH KGU 34645 GB
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 24, 2010 | Microwave Ovens
Hi. I have an Amana/Maytag Fridge. Model ABD2233DES bottom freezer. The fridge was working fine, then it seemed like the compressor or motor started to make a funny noise. Like it was working hard or...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
Siemens fridge freezer kg30u694gb has droped temperature from -23 to -4 is that normal also alarm is on
No. The freezer's ideal temperature is -18 and if this has dropped it can be due to many issues.
It can be the gas pressure, the pumping of the compressor if there is no coling even after switching off for several hours.
If cooling returns after several hours it can be auto defrost timer, thermostat or poor defrost heating
Aug 28, 2010 | Microwave Ovens
Stopped working although power is still going to the fridge, the dials read - freezer 2 C and fridge 14 C...
Shut off fridgge and power on after some 6 hours. If the temperature in freezer goes to below -5( ideal -18) then the system is working fine. If the freezing stops after several hours then it is possible that the thermostat is not working or the auto defrost timer is not shutting off the system,
However is there is no cooling then the compressor or gas pressure is down.
check this out to confirm
Aug 27, 2010 | Microwave Ovens
Microwave Ovens Logo
314 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
