Question about Toshiba e-STUDIO 120 Laser Printer
How to reset developer count of toshiba e studio 120
taran_2005
  • 10515 Answers
SOURCE: On a Toshiba e studio
The procedure is explained below :-
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]"000""000" will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] "000""000" will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY'S PAPER SIZE SETTING
Follow these steps to change a tray's paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2010
  • 4 Answers
SOURCE: Changing the Developer on a Toshiba E-Studio28
just take out the top cover of the unit, dispose all the used developer material and next fill it with new, after mounting back on the machine do code 200 of the service mode 05, that's all
Posted on Oct 01, 2007
  • 190 Answers
SOURCE: need driver for toshiba e-studion 120
Dear customer,
                Please try the following links  http://www.copiers.toshiba.com/support/controllers/e-studio120.shtml
http://driverscollection.com/?H=e-STUDIO120&By=Toshiba
Please rate this solution.. Thank You..
Posted on May 03, 2009
  • 30 Answers
SOURCE: copier reset code on thshiba
Hi how are you this is jack... jack_pak@hotmail.com
COPIER E-STUDIO 45
Dear, You on your copier 0 and 8 mode and change 251 value.... or set 0 value.
PLEASE VOTE ME.
Thanks.
Best Regards,
Posted on Aug 14, 2010
SOURCE: toshiba e-studio 161 developer
Sir, i added new toner and new developer but my printout is dull. What i do?
Posted on Dec 08, 2010
Thoshiba e studio 120. What does error code H4 mean?
The Code H-4 Mean the copier needs to be reset. Also I have added a link to help you troubleshoot the copier.
Thread Toshiba studio 120 with error code H4
Mar 17, 2016 | Office Equipment & Supplies
E studio 600 error cod f 105 how can reset
sir i have a toshbia estudio 600 the copy is coming light but i put the toner manually in the developer tank the copy is o.k. toner is full and the developer also new
Dec 01, 2013 | Toshiba E-STUDIO 650 Copier
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
Toshiba e-studio 161 developer low functions reset code
Nov 18, 2010 | Toshiba e-Studio 161 Copier Copier
Copier reset code on thshiba
COPIER E-STUDIO 45
PLEASE VOTE ME.
Thanks.
Best Regards,
Apr 19, 2010 | Toshiba Office Equipment & Supplies
Error - Service Recomended SPC
The message can be reset. 08-800 set to "0"
Feb 17, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
My Toshiba Studio 150 has a wrench lit up on the screen. Any Ideas?
Hi, the two main reasons for the Maint error light (spanner) to come on are the toner warning when it reaches 10% full and the developer when it reaches 25k count. The light can only be reset by entering one of the pre programmed simulations on the machine and clearing the error.
Dec 08, 2009 | Toshiba e-STUDIO 150 All-In-One Laser...
Change Developer indication doesn't go of even after replacing the Developer?
after replaceing the developer you have to clear the counter by going into service mode for techs and clear the total count for the developer to do this you need the service manual.
Dec 15, 2007 | Toshiba e-Studio 161 Copier Copier
Toshiba e-STUDIO 120 Laser Printer Logo
1,095 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
