Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
I would like to have the diagram of the motherboard that indicates how the case switch and usb connectors should be attatched
    Scholar:
  • 59 Answers
Here you can download the full manual for your motherboard, you will find the diagrams necessary in it.
Hope this helps
Posted on May 18, 2011
Power supply diagram for ht 2000 motherboard
http://www.ebay.com/itm/ECS-HT2000-AMD-AM2-Socket-mATX-DDR2-800-Motherboad-w-NVidia-Graphics-/251260314586?pt=Motherboards&hash=item3a804823da
1) Uses one 24-pin ATX main power cable.
Motherboard installed in computer case, the motherboard connector for the 24-pin ATX main power cable; is to the Right of the Blue IDE (PATA) connector.
(Right side of motherboard)
General example. Note that color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Uses one 4-pin ATX +12 Volt power cable,
Motherboard installed in computer case, the whitish square 4-socket hole connector, to the Bottom/Left corner of the Processor socket; is the 4-pin ATX +12 Volt power cable's motherboard connector.
General example. Note color does NOT matter of connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
THAT, would be considered a Power Supply diagram of the motherboard.
They are the only two power cables that plug into the motherboard.
The front of your desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Power On switch, Power On LED, (Light Emitting Diode), Harddrive activity LED, and a Reset switch IF used.
Regards,
joecoolvette
Apr 15, 2013 | ECS HP MCP61PM-HM Nettle3-GL8E 6150SE AM2...
I have a new pc case on the front panel connectors their is one hdd led +- and one hdd led plug were do they go my case is a EVO LABS E-6690 BLACK/RED, 12CM LED FAN, INC DOOR AND SIDE WINDOW my mother...
You need to look in the handbook that cam with your motherboard for a section labeled 'Connectors' or possibly 'Connections'. There will be one USB 2.0 type prong on the motherboard that is designated for case connections [Power LED, mini-speaker, etc.]. The manual for the motherboard will indicate what order and where on the motherboard your connectors should go.
Good luck with your build. :]
Aug 26, 2011 | Computers & Internet
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with IntelĀ® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
Hi i have a Codegen model 450x case and i am trying to install a Gigabite GA-P35-DS3R motherboard and am having troulbe with the start switch wires, the cases wires do not matgh the diagram in the...
I'm not sure what you mean when you say the case wires don't match the diagram. You might mean there is already a plug on the end of the wiring, and this plug doesn't match the board header. If you're reusing the case from a name-brand machine like a Dell or HP, this is possible. They often get custom versions of motherboards made, and their front panel connectors are usually a nonstandard layout. On the other hand, in a generic retail case, the front panel wires normally have separate connectors on the ends for the switches, indicator LEDs and any front panel USB and audio jacks.
This is the front panel header diagram I found in the manual for your board (I looked at version 2, but the connections should be the same if yours is a different version):
This board has an Intel standard layout for the header. If your wiring has separate connectors, the start (power) switch wires will plug onto pins 3 and 4. I have never seen a retail case come with anything other than a two-pin plug on the end of the power switch.
If you are dealing with a custom plug on your case's wiring, what you can do is remove the pins from the housing. They almost always are held in by a plastic tab on the connector shell that engages a tang on the pin. Use a thin object like a small flat-blade screwdriver or a knife tip to lift the tab and you can slide the pin out. Insulate each pin with small-diameter heat-shrink tubing if you have it, or a layer of electrical tape. (I prefer the heat-shrink tubing, which is neater and more permanent.) Then you can put each pin over the corresponding pin on the motherboard's front panel header. Unless the pins are very loose, they will stay in place by friction. I often use this technique when salvaging a case.
As for the CPU fan, be sure you have the connector over the right pins. Here is the diagram from the manual:
You might need to rearrange the pins in your fan power connector if they don't line up correctly. This layout looks a little strange.
Dec 21, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
Need a diagram of ga-k8vm800m to rehook my front usbs
Open the link provided below;
http://www.directron.com/installusb.html
Most likely you'll use: Common USB case header connectors. Or Intel Standard USB header Layout.
Enjoy!
Mike
Apr 15, 2010 | Gigabyte GA-K8VM800M Motherboard
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
May 12, 2009 | ASUS Computers & Internet
M863G V1.5 SW1 header
If your connector on the compaq case is a single conector for all the leads for the switch and LEDs, then make a diagram of how the pinout of the motherboard header, a pictorial or what ever is easiest for you . and label the connections.
Next trace out the wires to the switch and LED on the case and and identify them. use tape to pair them up or label.
I would then remove the wires from the connector and then reposition the the wires to match your header or pinout. That would be one way to fix the difference in pin out between connectors.
The only problem I see is if the new case connector is totaly different and would not plug on the header, unless some modification is made.
Jul 22, 2008 | Chips M863G V1.5 Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
452 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
