Broadcom undi pxe-2.1 v14.0.8 cames up - Computers & Internet
My E-Machines Laptop keeps alarming when i switching on and it will only be silent upon pressing any key on my keypad
Posted on Mar 28, 2014
  • 13433 Answers
SOURCE: my acer aspire 5315 is stuck n i have no disk to reformat
the computer can't detect the hard drive to start from it or, then theres a problem with your windows. Use the recovery discs or windows setup cd to try to install windows to the computer again to fix the problem. Let me know how that goes. Thanks
Posted on Jun 07, 2009
syedmujahed
  • 158 Answers
SOURCE: no boot disk
when this error is showing give me details
mujahed@imsindia.co.in
Posted on Sep 27, 2008
SOURCE: Broadcom UNDI PXE-2.1 v10.0.9
hia its easy to handle it,easy at bios put chose: boot from lan=disable
Posted on Nov 09, 2008
  • 100 Answers
SOURCE: My computer which got on friday is not working
What is your computer brand?
Just turn it on and keep pressing esc or delete or F2 key (depending on the model. But yuo can try any of them. This will take you into the bios screen. In the bios check if hdd is detected. If not - replace HDD>if yes > reset bios to defaults and start recovery (using supplied RDVDs or Recovery partition.
You will find exact instructions in user manual.t
thanx
Posted on Sep 14, 2009
elix0411
  • 3530 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Posted on Apr 04, 2010
First ther was a error message, then the pc make nothing.
If you have a spike in the power, unplug, remove the battery, then hold the power button down for 1min or 60s, to release any built up shock power. then insert the battery, (no power cord) push and hold power button for 1 -2 - 3 s. release and see what happens.. now what OS is installed on the HDD. and check the BIOS to see how the boot sequence is set... seems your error show you set to boot to NetWork not HDD
May 28, 2014 | Acer Aspire 5500 5570-2609 Laptop
Broadcom UNDI PXE-2.1 v12.20 copyright(c) 200 - 2009 broadcom corporation copyright(c) 1997- 2000 intel corporation all rights reserved client MAC ADDR: 88 AE 1D 6F 5A 3A GUID: 478ADE06 B852 67B5 10E7...
From the description it is the hard drive, remove hardware and reseat back into position, sometimes this will restart the hard drive, if no change chances are you will need it replaced, but I would suggest getting it tested first.
May 26, 2012 | Acer Aspire Computers & Internet
Problem with acer laptop. My laptop stopped booting after restart. I just moved my laptop from bed to floor . while in power on the program just crash not responding, then came a blue screen and said...
Click the power button and watch the screen to see which key it says to press to get into the Bios or System Setup. Change the boot order or boot sequence. It looks like it is set to boot from a Network or LAN first. You want to boot from the hard drive 1st or the cd drive 1st and the hard drive 2nd. This will change it permanently. Then reboot.
There might also be an option to change it temporarily when you boot the system. Just watch the screen and see if it shows you which key to press to change the boot order or boot sequence. It is only effective for this one boot.
Apr 28, 2012 | Acer Computers & Internet
Hi, When I turn on my Laptop - Acer Aspire 5536, the following writing appears; Broadcom UNDI PXE-2.1 v11 .4.1 Copyright (C) 2000-2008 Broadcom Corporation Copyright (C) 1997-2000 Intel...
usually, this message means that when your computer is booting it is trying get the operating system files from a network location (shared folder)
what you need to do is to make sure your BIOS is not set to boot from network.
1. when the computer starts, there is a message like "to enter BIOS press Esc" or any other key like F2 or F10
2. in the BIOs settings, make sure the order of the boot is: DVD/CD then hard disk. make sure there is no Network booting in the list
Oct 26, 2010 | Acer Aspire 3690-2196 Notebook
Prablon may loptop pxe-mof exiting broadcom pxe rom .broadcom undi pxe-2.1 v14.0.8
I think you hard drives failed. When the hard drive fails, the boot tries to find another way to boot up, so if the boot sequence lan is enabled, it will try to boot from the lan port (in your case broadcom pxe), when it can't boot from here either, it exits (exiting broadcom pxe). Replace your hard drive and re-install windows.
Oct 14, 2010 | Computers & Internet
I have Dell Studio 1555, Vista but later intalled XP on drive D, I have problem my CD/DVD drive does not read the Data, CD does not revolve in high speed make the tak tak sound as it try to read bit after...
Your message indicates that Pxe Boot is enabled (boot from lan card), go to bios settings and from the list of first boot options, please select the hard disk (hdd) or Cd-rom as the first boot device, reboot your system and check whether this helps or not.
It is also necessary to disconnect and reconnect your dvd/cd rom's power cable and data cable.
If you don't know how to do, then just reset the bios settings to "load default" ...
Good luck.
Thanks for using FixYa.
Jun 24, 2010 | Computers & Internet
Mar 31, 2010 | Lenovo 3000 G530 Notebook
My computer which got on friday is not working, when i start my computer it goes to a black screen. And than this message comes up: Broadcom UNDI PXE - 2.1 v11.4.1 Copyright (C) 2000-2008 Broadcom...
thanx
Sep 14, 2009 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
928 people viewed this question
David Payne
David Payne
