Question about Sylvania G-Netbook
My netbook got wet. Now the number buttons don't input one number they input three of the same number. My left mouse button doesn't click it is now working like the right mouse button. HELP???
My netbook dosnt work at all..the other day it drop into my bath tub...i tryed to
reset it..the one thing happend is the scene came up mass up
Posted on Aug 07, 2012
    Genius:
  • 1,267 Answers
I suspect that your net book has not dried out completely and has left a moisture trace on the membrane keyboard that is shorting to another trace. Heat the oven to 100 degrees (caution, do not go over 110 degrees), and place the net book in that 100 degree heat for a few hours. Hopefully any lingering moisture will evaporate and leave the key traces clean.
Posted on May 19, 2011
Mouse buttons spontaneously click themselves
I'm afraid that keyboards and mice don't like tea much at all. You can pick up keyboards and mice cheap enough and to be honest they are just not worth repairing. Even a tin of Servisol Video 40, which you can spray on the contacts to clean them will cost you as much as a mouse would!
Mar 12, 2017 | Logitech Cordless Mice 910001822 M510...
Can't print screen in netbook
Print Screen
Use this method to print screen.
Press and hold down the Alt key and the press the PrtSc key, this places the screen image into the Clipboard. .
Open a blank Word document and then Click on Edit - Paste.
The image is then places onto this page, you can up the image by holding down the Shift key and then place the cursor on the bottom corner of the image, then press the left mouse button and drag it down to the right, release the mouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correct proportion.
You can now print this image document and or add text before printing.
Sep 22, 2012 | HP Mini 110-1037NR Netbook
Sigmaplot 9 will not run with windows 7
1. Click the RIGHT mouse button on the icon for "SIGMAPLOT 9"
2. On the menu that appears click "PROPERTIES" with the left mouse button. This will give you a properties window.
3. Click on the "COMPATIBILITY" tab at the top right of the properties window with the left mouse button.
4. Tick the box "RUN THIS PROGRAM IN COMPATIBILITY MODE FOR:"
5. Click the drop down arrow and select the version of windows it ran in before or try "Windows XP Service Pack 3" and click APPLY.
If that doesn't solve the problem repeat steps 1 to 4 and this time select windows 2000. This should solve the problem.
Apr 20, 2012 | Systat SigmaPlot 9.0 (000053608314) for PC
I have a problem with the mouse for 5euro This technique tknm110 mouse and the problem that I have a normally lit mouse is a optical mouse, but mouse does not work ... it's two the same, at first I...
Hello ania1997,
I've seen this 'problem' before.
First, disconnect the "Mouse."
Next, click on the "Start Button."
Now, click on the "Control Panel," in the 'start menu'.
Scroll in the Control Panel, and select the "Mouse" applet!
Open the [Mouse Properties], by 2x clicking or,
Right clicking,and open.
From here you want to [Disable the Touchpad Device].
!Beware, that now, you may have to "Manually Navigate."
Without the 'mouse; you will use the "Tab, Arrows, and 'Enter' buttons,
to perform tasks, if the 'optical mouse' doesn't work the first time.
"Restart the computer."
Connect the "Optical Mouse."
"The {Mouse should be detected automatically}."
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Jul 28, 2011 | Computers & Internet
My mouse keeps on skipping clicks, I don't know why. The wireless connection seems to be in order and everything else seems fine.
Did you try changing the batteries? If so, try unplugging the mouse receiver and plugging it back in. If that doesn't do anything, how long have you used the mouse? My mouse skips clicks because of my normal use over the years. Might just be the wear and tear to the little clicker button, but try changing batteries.
Jun 22, 2011 | Dynex Wireless Optical Mouse
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
I was dusting my acer monitor and microsoft wireless keyboard and i must have hit something because now my monitor is reading sideways and the mouse wont work with it either. Can you tell me what I need to...
Sounds like you changed the orientation of your display settings from landscape to portrait.
In Windows 7 you can go to the control panel, choose display and click "Change Display Settings" on the left side.
From there choose the "Orientation" dropdown and change to your desired setting (most likely landscape)
Good luck
May 12, 2011 | Acer AL1916W 19" LCD Monitor
Just connected a HF 225 monitor to Vista Home 32 bit. No real manual; install CD does nothing. When I press the Menu or Brightness buttons on the monitor I get no response to keyboard or mouse clicks to...
They only include the Win7 driver on the CD. I'm surprised it doesn't work with Vista. Did you try going into the HF225_win7 directory and clicking on infinstallWIN7?
The monitor menu doesn't work with the keyboard. You have to press a combination of the three buttons to the left of the on-off button. It's not very intuitive.
Aug 08, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
HP Wireless Mouse Left Click Doesn't Work
Try using a different mouse on the same computer if it work.... run a hard ware daignostic test on the old mouse.... and if you have purchased this before three months just get it replaced.... as it would be in warranty.... reply with any more queries....
Jul 30, 2009 | HP Computers & Internet
Acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Jul 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Sylvania G-Netbook Logo
115 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
