Question about HP LaserJet M4345 MultiFunction Printer
JAM IN DUPLEXER CONSTANT ON DUPLEX JOBS FINE OTHERWISE.I HAVE REPLACED DUPLEXER,ENGINE POWER BOARD,DCE CONTROLER,REVERSING ASSEMBLY,FUSER UNIT. ANY IDEAS.
    Genius:
  • 1,089 Answers
You've done everything I would have done and more.
How about you installing a DOA duplexer. At this point I would change it again. Is there another printer that you can swap duplexers with?
There is a paper path sensor test (letter H) and manual sensor test . I don't know if the Component test checks the duplexer, but you should be able to find out.
Is the printer still under warranty? Can you call HP or are you an HP tech and you can call 2nd level support.
Just a thought....when you run a Config sheet, does it show the duplexer?
Posted on May 19, 2011
I have a 69.0 printer error on my HP5100dtn printer.
Hi Mary L,
Good day... This steps may be helpful for you. try sorting one by one steps...below
solution 1:
1.The duplexer side adjust has failed.
2. Turn the printer off and then on.
3. Reseat the duplexer assembly.
4. Replace the duplexer assembly.
solution 2:
1. The duplex printing unit is not functioning.
2. Turn the MFP off, and then turn the MFP on.
3.Reseat the duplexer.
4. Check the connection between the duplexer and the DC Controller.
5. Replace the duplexer.
solution 3:
1. Duplex mechanism failure.
2. Duplex slide adjust has failed.
3. Temporary error.
Hope this solve the problem...
Thanks in Advance.
Hp Error Code 69 Service Errors 69 Printer Repair Message
Sep 15, 2017 | Office Equipment & Supplies
T632 duplex jams
Please ensure the power connector wires for the fuser are routed properly so as not to rub on the aluminum bar that is used during the duplex function.
Apr 03, 2013 | Lexmark T632 Laser Printer
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
I have a HP Color Laserjet 3600DN. The initial problem was no duplex printing. It wasn't pulling the paper back down. I replaced the duplex transfer belt. No luck. I then replaced the duplex reverse...
I've worked on these printers for years and I never heard of a "duplex transfer belt".
Sounds like you broke a wire or missed plugging in a connector.
Probably a bad Duplex Feed Drive assembly or bad DC Controller.
Jun 01, 2011 | HP LaserJet 5000gn Printer
13.20.00 jam inside the rear bin in a Hp 3005x printer...this is after a new fuser and the formatter board
I experienced also even I replaced new fuser assembly but still the same problem 13.20.00 error rear bin jam, I tried to fix this problem for almost three days by swapping the other spare parts from known good printer then finally found and fixed the problem. discovered that the paper sensor inside the duplexer is broken. I replaced the broken sensor and now the printer is working fine.
Oct 18, 2010 | HP LaserJet P3005d Printer
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 01, 2010 | Minolta DiALTA Di183 Copier
Xerox 5760 Color Copier has fault 03-302 at start-up
Xerox 5350, 5352, 5760 Code Description 00-009, 030, 031, 032, 033 A door was opened while paper was being fed 00-047 Paper in duplex 00-1 Auditron 00-2 Diagnostic error 00-3 Faults error 00-4 Ric error 00-5 Job manager system error 00-6 LLM interface 00-7 Standby error 00-8 Communications error 00-9 Xerographic error 01-300 Front interlock 01-310 Right upper interlock 01-315 Left upper interlock 01-320 Left lower interlock 01-325 Fuser interlock 02-910 Key counter missing 02-920 Wrong combination of accessories 03-302, 321, 322, 326, 327 LLM to ISIL communications problems 03-328 IOT communications problem with duplex or tray 4 03-330 IOT communications problems with HCF 03-335, 336 LLM communications problems with edit 03-340 NVM memory 03-341-347 Communications problems between IOT and sorter 03-350-354 Communications problem with LLM and user interface 03-363, 364 Communications problem between LLM & optics 03-370-03-373 Communications problem between LLM & DADF 03-380, 384 03-416-422 RAM memory problem 03-424, 426 NVM memory problem 03-430, 432 Billing problem 03-439 GRAIB communications problem 03-440 RIC communications problem 03-441 RIC NVM problem 03-442 Modem 03-443-458 RIC problems 03-460 Serial communications processor problem 04-300 Main motor or drive problem 05-100-108 DADF registration sensor 05-110 DADF exit sensor 05-115, 120 DADF jams 05-305 DADF document drive 05-310, 312 DADF document sensor 05-316 DADF registration sensor jam 05-325 DADF exit sensor 05-335, 341, 345 DADF interlock switches 06-300-310 Scan problems 06-315 Scan drive 06-320A, 320B, 320C, 325 Scan problem 06-330 Lens drive 06-340 Exposure control problem 06-342 LLM CPU problem 06-344-350 Exposure cvontrol problem 06-352 IOT CPU problem 07-300, 315, 330, 345 Tray faults 07-360-370 HCF problems 07-375, 380A, 380B Duplex problems 08-100-110 Feed problems. Lead edge of copy paper is late getting to feed sensor of tray 1 08-115-162 Feed problem. Lead edge of copy paper is late getting to registration sensor 08-165 Paper jam at registration sensor 08-310-370 Paper at a sensor when power is turned on 08-330 DADF nudger sensor 08-380 Registration side to side problem with home position 08-390 Nip 09-300 Copy cartridge finished (drum unit) 09-310 Add black toner Add color toner 09-320 Add color toner 09-330 Wrong copy cartridge (wrong drum unit) 09-340 Drum cartridge not installed properly 09-350 Waste toner full 100 A fault has occurred 10-100 Exit jam 10-105 Exit jam 10-110 Vertical sensor jam 10-120, 122, 125 Duplex jam 10-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 10-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 10-310 High fuser temperature 10-312 Fuser not up to temperature after energy save 10-314 Fuser problem 10-320 Fuser web finished 10-330, 335, 340 Exit switch, vertical sensor switch actuated when power is turned on 11-100-116 Sorter jam 11-150-176 Sorter auto stapler jam 11-310, 314, 316 Sorter interlock 11-325A,B,C,D,E,F,G Sorter index 11-352, 354, 356 Sorter auto stapler interlocks 11-365A,B,C,D,E Sorter auto stapler bin 11-370,371,372A,373A,373B,374 Sorter auto stapler staple failure, staple home problem or tamper home problem 11-385A,385B,390A,B,C,D,E,396A Sorter auto stapler staple failure, staple home problem or tamper home problem 301 Fuser web must be replaced 302 Copy cartridge (drum unit) must be replaced 501 Tray 1 must be rebuilt 502 Tray 2 must be rebuilt 503 Tray 3 must be rebuilt 504 Tray 4 must be rebuilt 505 HCF must be rebuilt 506 Bypass must be rebuilt 507 Duplex unit must be rebuilt 508 Replace black developer 509 Replace red developer 510 Replace green developer 512 Replace brown developer 513 Copy cartridge (drum unit) will need replacing soon 514 Fuser web will need replacing soon 515 DADF belt should be replaced 516 DADF feed rollers should be replaced 517 Replace exposure lamp 518 Replace suction filter 519 Replace ozone filter 520 Replace optics filter 521 Replace particle filter 522 Replace upper fuser roller 523 Replace fuser pawls 524 Replace pressure roller 525 Replace pressure roller pawls 900-905 Key operator calls
Jan 16, 2009 | Office Equipment & Supplies
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Duplexing jams
Some of the rollers inside the printer have becomes slick with paper dust on the surfaces of the rollers. There is a printer cleaner paper available at most office supply stores and online. It is sticky on both sides. You run a sheet through the printer a couple of times and it removes the dust from the rollers. In your case, run the paper through the duplex unit too.
Mar 16, 2017 | HP LJ-8000DN Laser Printer
HP 2430tn lj printer with 13.20 jam inside top cover error
What is the exact error message shown on the display ?
Does it makes any strange noise when you start it up ?
Dec 31, 2007 | HP LaserJet 2420 Printer
HP LaserJet M4345 MultiFunction Printer Logo
374 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
