Question about Panasonic NIR71NR Iron
I have a Panasonic Iron NI-R51NR. I love this iron but it wont trun on. i dont know what is going on with it because it was working one day and the next I have this issue. This has happened before with this iron and i dont know how or why it turned on again. do you have any clue as to why this is going on with this product. i would go out and just buy anonther but at this stage in my life im lucky to have gas in my car to get my daughter to school everyday. I dont have the extra money to do this. If you could please help me i would appericate it very much. I will be looking forward to hear from you thank you. Sincerely, Debbie Shumard
oscarn
  • 110 Answers
SOURCE: My panasonic NI-R73NR iron went off and is not coming back on.
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Posted on Sep 21, 2007
SOURCE: My iron leaves white residue on clothes when I iron.
Supposedly vinegar helps. Follow the following link:
http://www.learnhowtoclean.com/clean-an-iron.html
I'd like to use this teachable moment to give a shot out to all the Ray Luv fans out there, the Giant fans out there, and people who flush the urinals after using them.
Posted on Feb 16, 2009
SOURCE: Wiring digram for Panasonic NI-A57SR Iron
Same issue i believe
with metal part laying flat (ironing position) and looking at bottom side, from the left to the right - white & blue leads, lamp(resistor lead), red then both black leads and other end of lamp.
im guessing the themal fuse is the lamp? what is the PN where can i get it.
i had a small shere fall out of the unit, besides the positioning switch where else would this be located?
Thanks
Posted on Apr 06, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Panasonic Iron won't heat
most iron cases can not be seperated from the iron plate but, if you can take off the bottom plate you will see a heating element and attached to that a small cylinder it has a point on one side and a flat end on the other it is called a thermal fuse and radioshack sells them
they are made in different versions so take the fuse in to get the right one clip it back in and your iron should work again
Posted on Apr 24, 2009
  • 12 Answers
SOURCE: panasonic iron NI-A56NR wont turn on
first test your heating element to see if it is working.
You can by pass the control module by removing it from the line. Just disconnect all wires that goes to the module and put aside, then, connect back lead to the far right connection and white wire to the third connection from the left. Be careful playing with electricity is hazardous to yout health if you don't know what you are doing.
Posted on Aug 20, 2009
How do i increase the iron heating temperature (thermostat) in Panasonic Electric Iron NI-22AWJ
Check the voltage at your power point, irons draw a lot of power. most irons have a temp setting switch cool med hot . If this a new iron return for service.
Feb 18, 2015 | Panasonic Irons
Iron always too hot
Problems with an iron's electronic complements should be dealt with by an authorized service center. It typically is more cost effective to replace rather than repair an iron with internal problems. if none of the dials heat works right. its a problem with the setting switch. good-day !
Jan 17, 2012 | Panasonic NI-R73NR Iron
Panasonic NIA56NR NI-A56NR Iron shut off and wont turn back on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Oct 04, 2009 | Panasonic NIA56NR NI-A56NR Iron
Apr 24, 2009 | Panasonic NIA56NR NI-A56NR Iron
Panasonic iron NI-A56NR wont turn on
Jan 17, 2009 | Panasonic NI-A57SR Iron with Auto Shut-off
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Iron is out of order
an appliance repair center could probably fix it but you have to consider the cost against a new iron
mostly it is more costly to repair than to fix
Oct 19, 2017 | Panasonic NI-A57SR Iron with Auto Shut-off
Aug 11, 2007 | Panasonic NI-R73NR Iron
Panasonic NIR71NR Iron Logo
170 people viewed this question
Top Panasonic Irons Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
Bill Boyd
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
