Question about Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
Hi, we're having a problem with the Rimage 2000i picking up discs from the drive trays before putting them in the printer. This happens sporadically but quite frequently - after a disc has been duplicated, the drive tray opens, the loader arm descends and picks up the disc but the disc catches on the small bits of plastic around the edge of the disc bed. This pulls the DVD off of the loader arm. After a couple of cycles of the Rimage trying to pick up the disc, it gives up and sits there with the tray open which means we can then push the disc up onto the loader arm, click retry and off it goes as normal. The only option we have come up with so far is to try and remove these little bits of plastic as they don't seem to serve a purpose. Anyone have an alternative suggestion? Thanks, Guy
SOURCE: CD loading arm works sporadically
Hi guys,
We had exactly the same thing (for years!), in our case causing pick failures about once every twenty disks.
The total and complete solution seems to be to upgrade your 2000i to the very latest firmware. I've just completed 500 disks with just one pick failure. Plus, as a very surprising bonus, the machine seems to work considerably faster overall.
MAN, the grief it would've saved us if Rimage had fixed this sooner...
Tony Sutorius
Unreal Films
Wellington, New Zealand
Posted on Jun 25, 2009
RimageCorp
  • 18 Answers
SOURCE: My Rimage 2000i will not begin production of cd
Hello B13Designs,
If you receive a "No Production Server Active" message when using QuickDisc, make sure that the Production Server status is set to Active, Processing orders in Rimage System Manager. Once the Production Server is set to this status, jobs can be processed.
1. Open Rimage System Manager.
2. Select Production Server. Production Server status information displays in the right panel, next to the Production Servericon.
3. If Production Server is paused or stopped, press the play button. Production Server starts.
If this does not fix your problem, feel free to give our support line a call @ 1-800-553-8312 (Option 2).
Thanks!
Posted on Nov 19, 2010
RimageCorp
  • 18 Answers
SOURCE: The Rimage 2000i recorder leaves streak marks on
Hello pwilford,
The most common cause for this issue is dirt and dust build up on the pivot tray. The pivot tray is the plastic piece the disc slides across when it is done printing. Clean this really well with some Formula 409 and it should "clean up" your issue.
Posted on Jan 17, 2011
RimageCorp
  • 18 Answers
SOURCE: The burner in our Rimage
Hello pwilford,
The most common failed parts in a system like this is the Hard Drives (not in your case) and the recorders. It is very possible that the recorders are going bad and need to be replaced. If you have a current contract or want to see if you can get one to fix the problem, please call our support line at 1-800-553-8312 (Option 2)
Posted on Jan 18, 2011
bronk50
  • 27725 Answers
SOURCE: My Rimage 2000i is not
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 08, 2011
Rimage 2000i driver
no drivers needed.
contact Rimage if you have a problem
http://www.rimage.com/gb/contact-us.html
Jan 30, 2015 | Rimage 2000i CDR 2 (52X), CD Duplicator...
I have a rimage prism plus why are my disc not clamping in on tray
Usually this is a bad printer pad, or your disc are not flat? Put the disc on a table, push near the edge of the disc and the opposite side should not lift up. In rare occasions the clamp pins will lower into the mounts. They can be raised with a flat screwdriver but be very carefull. If the pins extend above the CDs they will destroy the printhead ($575)
John Norman
Max Optical llc.
www.maxoptical.com
Jan 06, 2013 | Rimage Prism Plus Thermal Label Printer
Rimage 2000i is getting
Check its memory and i think it can solve the problem.
Performance Chip
Aug 28, 2012 | Rimage 2000i CDR 2 (52X), CD Duplicator...
The Rimage 2000i recorder leaves streak marks on the underside of the disc where the information is recorded; thus when attempting to playback the DVD, the player cannot read it.
Hello pwilford,
Jan 14, 2011 | Rimage 2000i Burner
Rejected discs
I had the same problem, with rejections getting more and more frequent. In the end replacing the DVD burners fixed the problem. Apparently, the red lasers that burn the cd surface fade with use. They are still fine reading the disk at low power, but burning at high power becomes progressively more hit-and-miss.
Jan 08, 2007 | Rimage 2000i CDR 2 (52X), CD Duplicator...
Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner Logo
100 people viewed this question
Top Rimage Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Mike Carew
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
