Question about Medion Laptop DC Power Jack MD97000, MD96630, MD96640 DC Jack Center pin diameter: 2.5mm (847197004684)
How can I dissamle the MD97000 to replace the jack?
My mg100dfx has almost no sound comin out of it
Don't replaced anything until you jumper the power amp in jack to the preamp out jack [or effects send jack to the effects return jack]. There may only be oxidation in the contacts of these jacks. If the normal sound level comes back-either clean the two jacks or have them replaced.
Apr 19, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Fix dc socket
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 08, 2011 | Medion Laptop DC Power Jack MD97000,...
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
I need to replace the headphone jack in my Casio 1630 keyboard. Do I have to replace the board it is on or can I just put in a new jack.
Just replace the jack. Search Digikey.com Mouser.com for exact replacement. It will be a stereo jack LIKELY with switches that disconnect the speakers if your unit has speakers, otherwise just a stereo jack.
Mar 04, 2010 | Casio Music
Rear springs replacement
You will need a spring compressor first of all. You have to remove strut, compress sring to get cartridge and spring apart and then replace new spring on strut and replace into vehicle. This is a nasty job without a hoist
Sep 24, 2009 | 1996 Pontiac Grand Am
Where can I get parts for my medion MD97000? I am in Adelaide, Australi.
Check the manufacturer site and check for the location near to you.
Aug 25, 2009 | Computers & Internet
Hp zd8000 power jack replacement
link
for purchase of power jack
will try to get more info on procedure
Aug 19, 2008 | HP Pavilion zd8000 Notebook
I have a medion MD97000 and it shuts down whenever it wants . It is intermitting and at random. Have any suggestions. Thanks Tony tonyzoppo@yahoo.com
- check for overheating, is it properly vented ?! Try to monitor the cpu and chipset temperature...
- it also could be a bad power source, open it (UNPLUGED), and see if there are any burned/blackened/bloated capacitors
- or maybe is just u;re power supplyer ... ?
Aug 08, 2008 | Computers & Internet
DC Power jack broken
Looks like you're right, I did not see any Lenovo replacement jacks either. You might try looking at the IBM Thinkpad jacks for various models to see if you can find the same jack.
I've repaired 3 laptops with this problem. Rather than replacing the jack on the mainboard I wired a "pigtail" to the mainboard and then zip tied a female connector to the back of the laptop itself. I did this because the mainboards were pretty beat up from the heat the original jack produced as it began to loosen. The end result is not as pretty as the original jack, but it absolutely takes all the stress off the mainboard. Those computers will never have this problem again.
Good luck.
Dec 09, 2007 | Lenovo 3000 V100 Notebook
Medion Laptop DC Power Jack MD97000, MD96630, MD96640 DC Jack Center pin diameter: 2.5mm (847197004684) Logo
56 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
