Question about Sony Playstation 3 (PS3) Console
When I try to connect my ps3 green light comes on and then follow the yellow blue with three beeps and hang up, all this very quickly. It seems that not getting set.
    President:
  • 1,139 Answers
Hi there, unfortunately this is what is commonly known as the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder joints between the CPU and GPU and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years
Hope this helps and thank you for using FixYa
Posted on May 18, 2011
  • ernandescf May 19, 2011
    was the best answer I got, thanks!
When i turn on ps3 green light comes on then blue light flashes then yellow light then flashing red light
Hello there Kevin
If you have the brief flashing yellow light, then its followed by a red blinking light then you have the yellow light of death AKA the YLOD.
The lights are a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the YLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click here to know more on PS3 Fix Manuals which has helped so many people like you.
Good luck
Best regards
Peter
Sep 08, 2011 | Sony Playstation 3 (PS3) Console
My ps3 goes to boot up an then shuts down beeps three times shows a blue light then a quick yellow light then goes to blinkin red light
You could try pressing the power button and holding it down. You will hear the first beep when you press it but hold it down until it beeps a second time it will take 5 to 10 seconds. This will reset the console and it may boot up. If this does not work you can go to www.us.playstation.com and check the user knowledgebase and/or support for a solution.
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
The yellow light keeps coming on when powered up
This is due to your fan inside your ps3. It has failed, or is failing and is causing a system failure. Unfortunatly it cannot be fixed. it will need to be replaced.
Contact sony or your insurance company
Hope this helped you, have a great day!
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
  • Beeps Three Times
  • Red Light Flashes
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Yellow light of deth
  • Beeps Three Times
  • Red Light Flashes
Ps3 80g light turns green flashes yellow, then
Unfortunatly your ps3 is dead, I am sorry for your loss.
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
