Question about Simrad AP35 GPS Receiver
AP35 Autopilot Hello, Thank you for the response. Are you referring to the rudder calibration values as stated on page 75 of the manual? If so, the values are being set correctly and are being stored correctly in memory. ==================================== ensure you are setting correct rudder value. Comment by ginko, posted on Aug 14, 2008 here is AP35 Autopilot Instruction Manualfind instructions on how to check rudder values stored on memory in the manual.
  • 19,396 Answers
Yep, if rudder calibration values are OK, then there is a real problem with calibration, it can be a mechanical problem or a faulty rudder feedback unit. Follow procedure at page 93 of user manual :
AP35 Autopilot Instruction Manualto troubleshoot the error, if you cannot get rid of the error message you may have to replace the rudder feedback unit or to have the unit inspected by a technician.
Posted on Aug 14, 2008
Turns hard to starboard when in auto
Verify that it is configured for your installation. Some units can be installed either on the port or starboard side, and they have to be programmed accordingly. Verify this in the user's manual.
Jul 04, 2013 | Raymarine St8002 Smartpilot Autopilot...
I AP 35 Setup
Aug 14, 2008 | Simrad AP35 GPS Receiver
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Autohelm ST 6000
Check the installation manual for initial setup,if system worked before ,check rudder reference unit for broken wire loose connection or defective unit (it is a potentiometer resistance shoud change smoothly with position)
May 21, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Trying to calibrate smartpilot, and controller shows large right rudder deflection. Repositioning the feedback piston has no effect on rudder readout. deflection is beyond the calibration range of -9. If I...
It sounds like the rudder feedback has a dead spot in the center of it. The replacement part numbers:
Rotary (inboard engines): M81105
Linear (outboard engines): M81188
Feb 15, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Where can I get an installation manual for a rpu80. I am installing an AP35 autopilot on my boat but the instructions do not cover the installation of the remote pump.
I have one right here. It covers the RPU80, 160 & 300. It's $15.00 plus shipping. Call me at 410-228-7335 if you're in the U.S.
Feb 01, 2010 | Simrad AP35 GPS Receiver
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Autopilot shows "no rudref"
The rudder sensor works like a light dimmer, so you get 5V and ground on the outside two connections and a varying voltage between about 1 and 4 volts depending on rudder position
Jul 07, 2009 | Raymarine Smartpilot Autopilot St6002 S1g...
Raymarine autopilot swings hard over immediatly i select auto
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Simrad AP35 GPS Receiver Logo
245 people viewed this question
Top Simrad GPS Experts
Will Halftowaite
Are you a Simrad GPS Expert? Answer questions, earn points and help others
