Question about Dishwashers
HI I have a heller dishwasher sometimes it will run fine but other times I will put it on and come back 2 hrs later and it still has not washed filled up with water or anything. Please help it is driving me nuts
  • 17,130 Answers
Check the inlet valve/filter, if this is clogged or has a poor flow at times the washer can delay or work erratic.
Secondly once the inlet flow is good check if the washer starts as soon as the level is reached. If not check the level detector. Finally check the drain pump/valve and see if there is any dirt clogging.
If none of the above is seen then the program controller must be checked in detail for any false action of the processor or a faulty board.
Posted on May 18, 2011
2001 lincon ls shuts off running and struggles to turn on
1)Reset the ignition timing to the manufacturer specification
2) Test the coil, and condenser and replace if necessary, when is cool work fine, but when heat the problem arise.God bless you
May 15, 2012 | Cars & Trucks
Run cycle
Sounds like the timing mechanism is messed up, call the repair place and see if they can fix it. other wise take the front panel off and see if you can adjust the dial that controls the timer.
Jan 09, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Normal light is flahing unit will not go on sometimes time remaining indicator will flash started awhile back by not being able to change any settings but unit would work now nothing have tried...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Feb 04, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
It is stuck on nine minutes rinse only cycle i will start it at normal wash (2 hrs) and it reverts back to the 9 minute rinse only.. When it is running I cannot cancel the cycle
Hi mlbierman, I have the exact same problem (The 9 minute rinse). Have you been able to resolve it? Will appreciate help. My email is sanjeevnutsATyahooDOTcom
Jan 04, 2011 | Maytag 24 in. MDB7601AWS Stainless Steel...
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Brand new dishwasher does nothing but wash & rinse
Time for warranty replacement or repairs! Good luck!
May 14, 2010 | Frigidaire PLD4375RFC Dishwasher
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Hobart LX 30H shuts off and turns back on by itself
Hello Jon,
I work in the product service department for Hobart Corp. and work mainly with the Hobart dishwashers. The most common problem with what you have going on is a faulty keypad on the front of the unit. This is the component with the actual on/off/wash buttons on it. If the problem is very frequent, then you could contact your local Hobart service office and they could come out and troubleshoot the problem to be certain that this is the faulty part before just buying a part and hoping that it works. If you would like to discuss this a bit further or need assistance as to a contact for your local Hobart office, you can contact us at 937-332-2525, and press option #2.
Have a great day!
Jim
Nov 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
