Question about Haier HWS08XC1 8,000 BTU Window Air Conditioner
My teco split aircon stops working in heater mode and displays an error on the unit-E1
E2 error
Posted on Oct 25, 2013
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
SOURCE: unit stops working - E1
Go to this address...it is on the first page. http://www.sharpusa.com/files/air_man_AFS60FX_S80FX_S85FX_R80FX.pdf You can also get to this address by clicking on the PDF symbol next to the link for the users guide. Clicking on the guide will not take you there.
Posted on Sep 07, 2007
mattozan
  • 555 Answers
SOURCE: E1 error code
You can contact Haier Technical Support here to open a support case for this error.
Posted on Jun 05, 2008
  • 1257 Answers
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
  • 23 Answers
SOURCE: i have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Posted on Jun 15, 2009
G'day I have a aircon model no.hrs70pca split system, it won't work on heating mode or auto mode even after 30min on each setting, any suggestions?
Make sure you have power to the blower unit. If you do, find the motherboard and check the fuse to make. The motherboard is usually attached to the front of the blower in the lower door of your heater.
Aug 04, 2016 | Heating & Cooling
How my aircon display E1?
High pressure or temperature cutout. Have the unit checked for a leak or a refrigerant flow problem.
Jan 31, 2015 | Heating & Cooling
WHY IS MY AIRCON DISPLAY E1 ?
THIS MEANS THAT THE ROOM THERMISTOR ( A DEVICE CONNECTED TO THE THERMOSTAT THAT DETECTS THE ROOM TEMPERATURE IS SHORTENED OR DEFECTIVE AND YOU NEED TO HAVE YOUR AIR CONDITION SERVICED
What wrong my comfortstar mini **** outside unit not coming on and I am getting e1 error code
I am somehow listed as someone who "solved" a Comfortstar mini problem - but I have not. And the company that installed it cannot. I am really fed up with the stupid thing.
Jun 17, 2014 | Ingram's Water and Air ComfortStar Mini...
Goes on when it wants to and it displays E1
can give the model of that aircon
Split type
E1 Indoor and outdoor communication abnormal
possible damage main PCB at outdoor units due to power supply problem.
Apr 08, 2014 | Haier HWR06XC6 Wall/Window Air Conditioner
Teco Split air on will not heat the room
Are you sure it's a heat pump type? If so, there is a valve in the outside unit that may be stuck or not getting power from the pcb. Give it a tap and see if it changes over
Jun 26, 2012 | Heating & Cooling
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
669 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
