Question about Printronix Line Matrix P5005B Printer
Show a massege close platen on printer sceen, then printer not working, what is this problem? then printer power off and after few times printer on then coming massege on printer sceen sdram loading 99%, offline,then press off/on/clear bootom there aftera massege come (close platen)on printer sceen.
2 Suggested Answers
LineMatrix
  • 34 Answers
SOURCE: close platen signal
When you open and close the platen lever you will notice micro switch that should be engaged... When the lever is down to A - C. looks like this... only 2 other things it could be besides the switch... 152417-001.jpg&w=70&h=39 152417-001 P5000 Platen Interlock Switch
If anybody has been in the printer where PCBA's are, check the two cable connectors holders... seated good... worst case,it would be very rare if its CMX Board(main logic)...
Posted on Dec 01, 2008
Ricoh fx200 scanner plate light is always on
The platen cover of the original glass is closed?Check the platen cover contacts.
Jan 31, 2013 | Ricoh Aficio FX200 All-In-One Laser...
How to fix platen cover need to closed ir-1210 canon copier
Sep 25, 2012 | Office Equipment & Supplies
Printer says inkjet not installed properly but it is and both are full.
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 23, 2010 | Canon PIXMA iP1600 Printer
My Canon PIXMA iP 1600 - Waste Ink Absorber Almost Full what do I do?
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Then download this tool unzip it and start it.Select the connected USB port number from USB PORT.Click LOCK RELEASE, and select the applicable model name in SET DESTINATION.In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Oct 14, 2009 | Canon PIXMA iP1600 Printer
057 close platen
Load the paper and close the forms thichness guide. If the error does not clear, power off and unplug the printerRemove the paper guide assy or pedistal top cover. Disconnect connector P107from controller PCB. Check continuity of platen interlock switch from P107 to switch. Replace the platen intetrlock switch if it fails continuity
Oct 07, 2009 | IBM 6400 Matrix Printer
Hi, my canon mx310 is showing a daRK line when we
Use a flashlight and look closely at the narrow glass next to the platen glass. I usually find a spot of white out on the glass causing the streak. Also a dark spot on the white guide above the glass will cause a streak like you mentioned.
Jun 22, 2009 | Canon PIXMA MX310 All-In-One Printer
057 close platen error message
Its located in the adjustment section of the platen control or in the platen itself.
Lexmark may still be supporting this model printer.
Dec 02, 2008 | IBM 6400 Matrix Printer
Platen opeo error
CLEAN THE PLATEN SENSOR IF NOT SOLVED CHANGED THE PLATEN SENSOR.
Sep 15, 2008 | Tally T6218 Matrix Printer
2410 Malunction
This problem always hits after a power interruption. On another site I read the solution is to open the back and roll or move the paper wheels back and forth a few times. This worked for me.
Apr 21, 2008 | HP Photosmart 2410 All-In-One InkJet...
Close platen signal
Apr 16, 2008 | Printronix Line Matrix P5010 Printer
Printronix Line Matrix P5005B Printer Logo
159 people viewed this question
Top Printronix Office Equipment & Supplies Experts
Cliff
Nick
Are you a Printronix Office Equipment and Supply Expert? Answer questions, earn points and help others
