Question about Indesit Dishwashers
I have an Indesit IDL 735 model dishwasher. It wont drain the last bit of water and the first lgreen light is on when I try to start a cycle and it wont run. I think it may be some sort of block?
  • Indesit Master
  • 17,129 Answers
It is so common that the drain blocks in many ways and is the most problematic fault in a dish washing machine due to waste food particles. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important.
Posted on May 18, 2011
Testimonial: "Yes - I undid the bottom plate - removed the pump (one screw) and freed up the pump) - presto its working again!"
Find me manual for indesit dishwasher model no. IDL 735
go to www.retrevo.com or www.fitness.manualsonline.com
get it and downalod free
God bless you
Apr 05, 2013 | Dishwashers
Indesit IDL 40 slimline dishwasher does not drain completely
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl 40 model, leaves dishes dirty and a dirty film on glasses.
First check if you are getting enough water into the DW, by opening the door after the fill cycle and see if you have about 1/4-1/2 inch of water by the edge of the tub. check that the water in the DW is hot (higher than 120 F) last, you may have a box of old DW detergent
Jul 20, 2008 | Indesit Dishwashers
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Apr 12, 2008 | Indesit Dishwashers
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
694 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
noel
noel
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
